Results 1 to 7 of 7
Thread: Pool scum
    DSdiver's Avatar
    Sep 2013
    South Eastern Wisconsin
    28
    Pool scum
    It's been a good year so far for our pool keeping the water crystal clear has been easy thanks to all the help from folks on this site. A few days ago we were visited from an old nemesis a slight amount of a scum on the surface of the pool. We had this last year and never got rid of it until this spring after we reopened our pool. It very hard to get a picture of but it looks like it could be a build up of sunscreen. It won't suck into the filter because it just floats on the surface after 2 min of swimming our turning our fountain on it's gone never to appear until the next morning when we retract our cover and there it is again. Not sure what to do we bought some scum balls and it sucks some up but not all. The water is crystal clear other then the light scum ,it also only covers about a 1/3 of the pool kind of like a small oil slick . Any thoughts our help ?
    As an after thought we have scrubbed our cover with water and a small amount of bleach but this didn't work.
    FC 5
    CC.5
    CYA 60/70
    TA 210
    PH 7.6
    Salt 3100 ppm
    20x40 IG vinyl lined 34,100 gallon/Hayward filter EcoStar model SP 3400 VSP/Hayward filter(sand) model S310T2 flow rate 98GPM/RayPack gas heater model 266 266,000BTU/Aqua Plus Automation and chlorination with Hayward Turbo Cell T-Cell-15/Hayward universal color logic light/ Delta UV filter/4 return lines 2 skimmers and dual main drains/Auto cover/ Pool is 3 years old. TFT test kit XL speedstir.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Pool scum
    There are several options:
    Jan 2012
    'burbs of Augusta, Georgia
    7,266
    Re: Pool scum
    Perhaps running the pump a tad bit more and boosting the chlorine a bit higher to allow the filter to work on it? Or adding a bit of DE to your sand filter? How about banning all those sunscreen products for a week or so and see if that makes any difference?
    That's all I got.
    DSdiver's Avatar
    Sep 2013
    28
    Re: Pool scum
    Thanks guys,
    I'm going to bump my FC up for a few days and let it sit and see. Is it possible to get rid of something like this without doing a full SLAM. I'm thinking maybe bring my FC up to 10 and hold it for a few days. I have some of the pool perfect enzyme is that maybe the better way to go?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Pool scum
    It depends on what it is but something like the "Scum balls" or "Pig Mat" or in my case "Scum bugs" might be much cheaper, easier and effective rather than doing a SLAM.
    With something like the scum bugs the prices vary quite a bit and make sure you know if you are paying for one as in each or one pair.
    http://www.amazon.com/s/?ie=UTF8&key...l_3i722gq3i6_e
    Solar Blanket, Well Water, Borax Added. 68°
    DSdiver's Avatar
    Sep 2013
    28
    Re: Pool scum
    Thanks for the help guys, I raised my FC for a few days and pointed my returns up towards the surface at night to get some water circulation on the bottom of the cover,also added about 4 scum balls and this did the trick no more scum. Thanks as always love this site!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Pool scum
    It's always nice when it's a simple solution. Ok, back to swimming
