Results 1 to 10 of 10
Thread: New to Forum CYA question
    Aug 2014
    Coppell, TX
    6
    Hello,
    I wanted to start by thanking folks who have put so much useful information for novices on this website. This sit might have helped me keep my sanity too. 3 weeks ago I had algae in the pool with zero ability to raise Cl using shock or the tabs. However some elbow grease (repeated cleaning of the cartridges) and following BBB including shocking with bleach I seem to have a very clean pool.
    I have a question regarding the water chemistry. Measurement done using Taylor K2006 test kits.
    FC: 5ppm
    CC <0.5ppm.
    ph: 7.4 (lower than 7.6)
    CYA: 120 using dilution method. Thanks pool stores !!!
    TA: 90 (<100).
    Pool Pressure OK (cleaned it 5 days ago).
    Scrub pool every day.
    Pool Volume @18000 gallons. I will do the testing for others chemicals tomorrow.
    The pool looks very clean. I have no algae or cloudiness-the concern I have is with the CYA so high and both FC and CC holding up-do I need to worry about water sanitation? I add 2 cups of bleach in the morning and evening to maintain the Cl levels. I am little concerned about raising the Cl higher as I have young boys who are learning to swim and may/do ingest little water.
    I recently switched to BBB-promised to myself that I will never go to Leslie's pool.
    Thanks in advance for your inputs.
    Amit
    38,246
    Re: New to Forum CYA question
    Welcome to TFP!
    You need to maintain a higher FC level due to the CYA level to keep the pool safe. You should be keeping it above 8ppm at all times ... it is perfectly safe and lower active chlorine levels than you would find in an unstabilized public pool.
    Remember the pH test reads higher than reality when the FC is greater than 10ppm. This is one problem with keeping the CYA too high.
    Aug 2014
    Coppell, TX
    6
    Thanks Jason. Will do so.
    Per the pool calculator- I need to add 96 oz of 8.25% bleach to increase the FC from 5ppm to target of 8ppm (minimum). I will then do the FC loss test during the course of the day and also overnight. Hopefully this will provide me with the correct amount of chlorine to add everyday.
    BTW do I need to shock my pool again if I am able to maintain FC to 8ppm MIN?
    Welcome to TFP!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by akaistha View Post
    If you pass the overnight loss test, you don't need to SLAM again. Poolmath says your target should be about 12, and the minimum FC is 9. So if you raise it to 12 and retest it at roughly the same time tomorrow and it's above 9 , 12 is your target. If it comes up at 8 or 8.5, target 13. You'll know soon enough what the pool's appetite is.
    One caution: when FC is above 10, the pH test starts reading strange and you can't trust it. If you have the ability - water rationing or whatever - you would do well to lower the CYA. You won't really use more or less bleach every day either way, but it's really nice to be able to trust the pH readings. It doesn't have to be all at once; you can drain out a few inches at a time to water the lawn. If you close the pool for the winter and drain down, just deal with it then.
    Aug 2014
    Coppell, TX
    6
    Thanks Richard- overnight FC drop was about 2.5ppm. I had tested at 5ppm at about 7:00 PM and retested to 2.5ppm today AM. I have added more bleach to increase the FC to 7 ppm and will see how much FC is lost during the day.
    Location: Dallas/TX, 18000 gallons IG pool, Cartridge type pool filter, Hayward XL pool vac
    38,246
    You failed the OCLT. Are you gong to start the SLAM process? Your FC is much too low.
    Aug 2014
    Coppell, TX
    6
    Yes Jason. Tonight I will start the SLAM process. Based on the numbers from pool calculator and the CYA/FC relationship I will add 850oz to get to 39ppm shock value assuming a start FC of 7ppm. I will let it run overnight and then do the OCLT test. I will then maintain the FC to 12-13ppm range. I understand that the best way forward will be to get CYA down via pool drain but I am planning to do that during the winters (will also convert the pool to salt water...). I will post the results here.
    Aug 2010
    Dallas, TX
    4,052
    Given you need to replace a little less than 9000 gallons of water, I highly suggest you do this first. If you can get in the 70-80 range, you will be a lot better off for the SLAM process, and it will put you in the proper range for your salt system.
    Oct 2013
    Chapin, SC
    1,141
    Sounds like you're planning to end your slam prematurely. To end the slam you need to pass all three criteria.
    1. Pass the OCLT < 1ppm fc loss overnight.
    2. Less than .5ppm CC test
    3. clear water with no visible algae
    If you don't, you must I keep your FC up to shock level.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    May 2014
    Mesa, Arizona
    180
    Quote Originally Posted by RobbieH View Post
    Sound advice for sure! It would save you money in the long run.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
