Thread: Staining trouble shoot
    Dallas, TX
    227
    Need to trouble shoot these stains. The plaster is a little scratched/chipped and where to does there are brown stains. This only occurs around these scratches. I am in the process of selling the house and want the pool to look as good as possible. Was re plastered in 2010. Water specs are usually kept normal per the pool calculator app, but I do have higher than normal calcium, but tend to keep the PH slightly acidic per previous direction that you can live with higher calcium levels in a pool.
    Any ideas what to use to test what would take them off?
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Re: Staining trouble shoot
    If they are due to some sort of metals in the water, a vitamin C pill or two would confirm it.
    Put a couple in a sock or something, and hold it down on the stains. If the stain is lifted or noticibly lighter after the Vitamin has dissolved, then the stain is due to metal.
    The same test can be done with a chlorine puck for suspician of organic staining. (hold the chlorine puck on it for 10 minutes or so).
    Divin Dave,
    Dallas, TX
    227
    ok. i ll check around for vitamin c pills. don't have any chlorine pucks as the are the devil. do they sell in small packs?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    You can check walmart. I know they carry pack of 3 of the chlorine tabs. Dont know if they have singles or not.
    Divin Dave,
    Dallas, TX
    227
    Found a single at Home Depot just for future reference.
    Jul 2011
    Arizona & California
    805
    If the discolored spots are raised and very rough to the touch, it may be "calcium nodules" that is the problem.
    See this post: http://www.troublefreepool.com/threa...dules-in-Pools
    Sanding them off with wet-or-dry (100 grit) sandpaper may work best.
