Thread: Thank you to the mods.
    Aug 2011
    Cochranville, PA
    228
    I have been following the TFPC method for several years. I still have questions at times and by no means do I feel like an expert! I went away for a week and a half. I had my pool clean and balanced before I left. Because of the TFPC method I understood the amount of chlorine it should consume and measured out the amounts. They were added at 2 times while I was gone and when I came home it was just how I left it. All I did was test the water and added the proper amount of chlorine. And tomorrow I will be swimming as if I never left.
    1) The size of your pool in gallons 4440.
    2) The type filter you have is an Intex 28651EG Krystal Clear 3000 GPH sand filter
    3) If your pool is an AG (above ground)
    4) Intex 15 by 48 metal frame.
    Southeastern, Pennsylvania.
    38,275
    Re: Thank you to the mods.
    Well done
    Thanks for the kudos, but you did the learning and the work
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Congratulations! You're are a TFPCer.
    Butterfly's Avatar
    South Carolina
    10,045
    Good work!
    You're done SLAMing when:
