Thread: Pool water is cloudy
    Hi everyone,
    So if by chance you're one of the nice people that have been helping me after my stupid mistake (in short, i accidentally put a ton of CYA in my pool and had to drain it almost entirely), i have successfully filled my pool back up after 2 weeks of slowly doing it through our well. In that time it eventually turned a nice shade of green and yesterday I shocked it. My levels are as follows:
    FC : 3ppm
    CC : 0ppm
    PH : 7.4
    AK : 70ppm
    CH : 10ppm
    CYA : 30ppm
    using a Taylor K-2006 test kit
    What has me stumped is the cloudiness of the water. I had mentioned before that my sand filter probably needs new sand but I believe the concensus was that had nothing to do with it and was most likely my high levels of CYA (which made total sense). Is there anything else I can try here to solve the cloudiness ?
    History So Far
    1. 7/15/2014 : Discovered I had put in approximately 150ppm of CYA into pool.
    2. 7/16/2014 : Drained more than 2/3 of the pool
    3. 7/18/2014 : Began filling the pool back up to get it below 50ppm CYA.
    4. 8/3/2014 : Pool level back up to skimmer and is a nice shade of green. Shocked it overnight.
    5. 8/4/2014 : Came home from work and pool was blue and measured at what I reported above.
    So now that i'm at 3ppm for Chlorine, i assume I'd have to verify that it holds overnight or doesn't drop more than a few ppm. Am i being too impatient here to expect the cloudiness to be gone with these levels ? Should I shock it one more night here at the recommended 16ppm and hope that it holds within a few ppm overnight ? At a bit of a loss. Thanks guys,
    Scott
    Last edited by sbelgrave; 08-04-2014 at 05:57 PM. Reason: spelling and 1 of the dates was wrong.
    sbelgrave @ Westminster, MD
    Size : 16 x 32 x 4
    Volume : 12,000 Gallons
    Material :Vinyl
    Water Type : Non-Saltwater
    38,332
    Re: Pool water is cloudy
    You should not "shock" the pool. You need to follow the ShockLevelAndMAINTAIN Process until you pass the 3 criteria to stop.
    Jul 2008
    NJ USA
    146
    check your CH level i had this issue last week i brought it up to 260 level CH and ran pump 48 hours straight brushed pool everyday and water began to clear up u must be short on Calcium Chloride CH
    19000 Gal. Fiberglass Inground 44x18 irregular shape pool
    Heat Siphon heater , Cooper Ind. Ranger Series Sand Filter, 3/4 HP Speck pump, Astral inline Chlorinator
    Aquacheck and TF100 tester
    NJ USA
    38,332
    Quote Originally Posted by rezasaba View Post
    There is no point in adding CH to a vinyl pool. And even if you did, that would have nothing to do with the water clearing up.
    Butterfly's Avatar
    South Carolina
    10,045
    You should follow the SLAM process as mentioned by Jason.
    There is no need to replace the sand. Be sure to backwash/rinse when the pressure rises 25% above clean filter psi.
    Also, if you have not done a deep cleaning on the sand filter recently, that is recommended. http://www.troublefreepool.com/threa...-a-Sand-Filter
    Once you pass the OCLT: http://www.troublefreepool.com/conte...loss-test-oclt
    .............you can add some DE to the filter to speed up clearing the pool: http://www.troublefreepool.com/conte...-a-sand-filter
    You're done SLAMing when:
