Thread: pool pump died... Advice needed.
    Dec 2013
    Houston, TX
    15
    My pool pump died on friday. It's covered by the home warranty so I'm not overly concerned but, as of today, it's going to take them a couple days to get the necessary parts to fix it. So how do I keep the pool from turning green? Over the weekend I add bleach after the sunset, ran laps around the pool with the net in a vain attempt to circulate 26000 gallons of water... Any advice would be nice.
    26k gal | IG Plaster | DE | Pentair Superflow 1HP | TF 100
    38,274
    Re: pool pump died... Advice needed.
    Continue to add bleach around the pool and then brush the pool to mix it in. The wall whale brush moves a lot of water around.
    Jul 2014
    Hudson, wi
    81
    If you have a sump pump put it in the shallow end and run the garden hose to the deep end, that should help to keep things moving. Depending on what it was used for before you might want to run some clean water through it first.
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Dec 2013
    Houston, TX
    15
    Warranty came through quicker then expected.. Got myself a new pentair superflow 1hp)
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Life is good
    Solar Blanket, Well Water, Borax Added. 68
