Results 1 to 11 of 11
Thread: 10 ml test with R-0870 won't turn pink
    I tested yesterday morning and had 2.5 FC. I added 121 oz of 8.25 clorox to bump it up to 7 or a touch above. We lounged in the pool yesterday and I went to test this morning and the sample won't turn pink. No way I lost all fc one day. I added small amounts of acid over the past couple days to lower TA and was about to aerate to bump PH back up. Now this??? Water is clear and beautiful, fresh off of partial drain and refill to lower cya..
    The end of the tester spoon is black, but the powder inside is dry. Is there any way this suff goes bad overnight?
    Fc ???
    TA 140
    Ph 7.2
    Cya 30
    Brandon, MS
    20000 gallon in ground vinyl
    sand filter
    hayward super 2 - 1 hp pump
    Brandon, Mississippi
    20000 Gallon Vinyl Inground
    Sand Filter with Hayward Super 2 - 1 HP pump
    K-2006 Kit
    Jan 2013
    Houston, TX
    1,079
    Re: 10 ml test with R-0870 won't turn pink
    Doubtful. Try putting a drop or 2 of CL into the sample then add 870 and see if it turns pink. You could be at CL 0.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    38,262
    Do you have the yellow color matching OTO test? It is not in the K2006. That would tell you definitively if the FC was 0.
    I do not have the OTO test. Just what came in the K2006. I don't think I could be at 0 on chlorine after just one day with no algae when it has been tested daily and doing fine for the past 3 days.
    K-2006 Kit
    38,262
    Well, there is really no other explanation as to why the FAS-DPD did not turn pink. With 10ml water sample and FC expected to be <10ppm a single scoop of powder should be plenty to turn it pink if there was any chlorine in the water.
    Adding a drop of bleach to the sample would make the FC level way too high I think.
    I just read about Ascorbic acid eating chlorine. I did use two bottles of vitamin C tablets in a sock to clean steps yesterday morning. Do you think that little of Vitamin C tablets would zap chlorine down?
    K-2006 Kit
    38,262
    Certainly would be a contributing factor.
    Well I adding 121 oz of 8.25% before I left for work this morning. I will add a couple drops of it in test and see if it turns pink this afternoon, before I test pool water again.
    K-2006 Kit
    38,262
    Don't add drops of bleach in your test. 1 drop in 10 ml of pool water would be the equivalent of adding 1 gallon to 200 gallons of water ... which would make the FC level in your test 424ppm. The sample would not turn pink, it would bleach out.
    Just test the pool. Really you should have added the bottle of bleach and tested the pool after 30 minutes to verify the FC level.
    22,544
    That vitamin C definitely neutralized all your FC. It may take several bottles of bleach to get the FC back, AND since it's been zero for a while you probably need to SLAM. It would probably be a good idea to just in case.
    I came home and tested yesterday afternoon around 5:30 pm after putting 121oz of 8.25% in yesterday morning. Still wouldn't turn pink. I added 242oz and tested an hr later. It read 11ppm on this test so I felt better. Tested this morning at 6:30am and still reading 11ppm. I am going to test again this afternoon when I get home.
    Brandon, MS
    sand filter
    K-2006 Kit
