Thread: Help with Numbers
    Jul 2012
    Hicksville, NY
    18
    Help with Numbers
    TC- 10-20
    FC- 5
    CA- 30-50
    TA- 40
    PH- 8.2
    Some of these numbers seems really high. I have a salt water pool. I shocked the pool because it rained for days here and these are the numbers I pulled tonight. Please help me adjust my pool. TIA
    Hicksville, NY
    4,500 18' x 9' x 52" Rectangle Intex
    Above Ground Vinyl Pool
    Intex Krystal Clear 2,800-Gallon Gallon Sand Filter
    Intex Salt-Chlorine Generator
    38,285
    Re: Help with Numbers
    What are you testing with? I am going to guess strips, which are worthless.
    Have you already read ABCs of water chemistry in Pool School?
    Jul 2012
    Hicksville, NY
    18
    I have a salt pool this year so I didn't think that I would need an expensive kit. I was told to get my CYA up since it was down to 0 and not holding chlorine. So I did that and now it's all out of whack. So what do you suggest?
    Hicksville, NY
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by Noangelny View Post
    What exactly did you do to raise CYA / How much stabilizer did you add ... and when?
    And is your reading of 30-50 Calcium or CYA?
    I will be the first to chime in and say you need a good test kit so you know what your numbers really are. Assuming they are correct (which they may or may not be) your first step is to reduce your PH.
    How does the water look?
    Provide all of this info, order a test kit which you will get in two or three days and we will get things squared away and you will have a good solid month of swimming left this summer!
    I know it sounds like a big sales pitch when all of the posts you read on here say "buy a good test kit" but it isn't .... a good test kit is the foundation of pool care. You need to know your pool chemistry to effectively manage your pool.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Oct 2013
    Chapin, SC
    1,141
    Who told you to add cya? It wasn't anybody here-- today's posts are the first you've had for over 1.5 months. If you have a pool, you need an adequate test kit. Neither test strips or pool stores fit that requirement.
    In fairness, Jason did suggest you needed to add cya back on the 14th of June.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2012
    Hicksville, NY
    18
    Quote Originally Posted by timerguy View Post
    Actually yes I did add the amounts that Jason suggested to me. I just hadn't been on in awhile. It has only been in the 70's here in NY so I will invest in a good pool kit for next year and a pool heater. My water was always freezing and unfortunately located under a tree that my neighbor has. Will have to move things around next year.
    Hicksville, NY
