Thread: Do I have a bomb?
    Aug 2014
    N.hollywood ca
    1
    Do I have a bomb?
    Hi all, I have a cheap summer pool with a chlorine generator. I covered it with plastic while I went out of town for the weekend, (we were expecting rain) I'm back and realizing that I may have produced enough hydrogen under my plastic to be a serious problem. Do I have a problem? Should I call the fire department?
    Thanks, holding my breath, Kevin.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Do I have a bomb?
    Welcome to the forum!
    Why would you think that would be the case? If anything it would be nitrogen that would build up, but it would have to be a pretty dirty pool. I leave my solar cover on all the time when we're not swimming, and when on vacation, up to seven days at a time. I wouldn't worry about it.
    Jul 2014
    Dallas, TX
    20
    Quote Originally Posted by Kdix View Post
    Need more info, but do you have something like a Uniclor chlorine generator that you covered with plastic? If so, just turn it off, and wait a while, longer to be safer, but do not cover it in the future! It's designed to be out in the weather, and it does release hydrogen gas, so the vents on the top must not be obstructed. I doubt you have a "bomb", since hydrogen dissipates pretty quickly.
    25000 Gallon gunite and plaster, 100 perimeter feet. Pool built 1996, original owner.
    Uniclor 2400 external brine membrane chlorine generator.
    Kreepy Krauly inground cleaner, suction side.
    Sta-Rite System 3 filter, 300 sq foot cartridge with 1.5 lb cellulose filter aid used.
    Sta-Rite Max-E glass 2 HP pump, Solar Cover for heat retention and evaporation control.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Hydrogen will collect under the cover but it probably would not ignite unless someone deliberately ignited it. I have collected some under my cover and I actually was able to ignite it but it requires the correct mix of oxygen. Pretty spectacular!
    Mark
    38,305
    I feel like there should be a "Don not try this at home" disclaimer
    ... seriously, Do Not Try This At Home!!!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Shut the chlorinator off, turn on the pump, it will flush out the cell, the gas should absorb back into solution, or come out the jets and dissipate. Then turn the SWCG back on.
