Results 1 to 13 of 13
Thread: How does a switchless 2 speed pump function?
    Nov 2013
    Miami, FL
    348
    Question How does a switchless 2 speed pump function?
    I've searched on this site and elsewhere but can't seem to find the information I'm looking for.
    I would like to better understand how my two speed pool pump operates.
    It is a Jandy/Zodiac PlusHP series pump.
    This is a copy of the box the pump arrived in.
    The pump is a switchless motor. What does that mean exactly? That it alternates between the two speeds automatically?
    The clock timer is currently set to go "on" at 8:00am and turn "off" at 4:00pm. There is also an on/off switch for "manual mode." What is the proper function of the clock timer? To turn the pump completely off or just switch to the low speed?
    I notice in the evenings that even though the water appears still, water is still flowing out of return lines. Is this correct? Also, for the evenings, to operate the spa or water features, I am switching to manual mode (using the switch under the timer) in order to operate the jets or water features properly.
    Swimming!: 19x32 IG rectangular pool, 22,500 gallons; 3' - 6.5'; open spa w/ 6 jets; raised wall w/ 1 sheer descent and 2 minijets, 2 color-changing LED pool lights, 1 spa light; Jandy 2 1/2 HP 2 speed Pump, Jandy cartridge filter (320 SQFT), Diamondbrite Cool Blue
    38,449
    Re: How does a switchless 2 speed pump function?
    I am not sure I understand what you got. I thought all 2 speed pumps needed a switch to change speeds. Can you post pictures of the actual motor, switches, name plate and wiring diagram?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    There's mention online that a switchless motor doesn't use a mechanical switch for the startup capacitor. It has nothing to do with the low or high speed circuits.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Nov 2013
    Miami, FL
    348
    Here are some photos. Let me know if you need to see more or something different.
    When I went out to take them (less than an hour ago!), the filter appears to be off (gauge is reading 0), but the pump is clearly running and water is flowing out of the returns. I see no switches to change the speed. My gut tells me something might be wrong here...
    Motor
    Switches
    Overview of equipment pad
    38,449
    I think gtemkin was right about the meaning of the switchless.
    That timer I assume is weird to switch the speeds. Do you not have another timer to turn the pump on and off? That would be lame.
    You may be able to switch the timer to power the pump on and off and use the manual switch to select speed. That would be preferred in my mind.
    Nov 2013
    Miami, FL
    348
    I believe you are correct, Jason. I turned off the "filter pump" switch and the pump shuts off.
    The pool was completed 3 weeks ago. I will contact the PB to see if they can correct this. It makes no sense the way it is currently designed. Thanks!
    38,449
    Usually a T-104 timer is used to turn on and off a 230V pump ... the T-106 that you have might be configurable to turn the pump on and off (I just can not remember). Or tell them to pull the timer and put in a 104.
    Definitely better to have the timer for the on/off and the switch to select speeds (unless you need the higher speeds for some part of each day to run a cleaner).
    Nov 2013
    Miami, FL
    348
    Well, PB told me that code requires the timer clock and pool pump to be installed this way. As you noted, the timer clock switches between the two speeds. I must manually turn off the pump using the switch. I'm going to double check that code because to me it defeats the purpose of the timer clock in the first place!
    38,449
    That is a bunch of baloney ... ask him specifically what code by number. Yours would be the only pool I have ever seen wired this way.
    Well since you can't start the pump in low speed you would need another timer to automate the high/low switching (T10604R). So if it is designed to run 24hrs cycle most of the time at low speed and part time at high speed this is the only way to do it with 1 timer.
    At that point you may want to consider something more advanced like a multiwave system.
    38,449
    Quote Originally Posted by az1324 View Post
    Well since you can't start the pump in low speed you would need another timer to automate the high/low switching. So if it is designed to run 24hrs cycle most of the time at low speed and part time at high speed this is the only way to do it with 1 timer.
    What? Why do you think that? There is no problem starting the pump on low speed, I start mine on low speed all the time.
    I thought it was recommended for most 2-speed pumps and also how the automation systems do it (enforce a delay before switching to low speed).
    38,449
    It is not required, although you are right that most automation systems do start on high for a few minutes for "priming". But if you do not have a leak, you should not be losing prime anyway.
    There are countless members who have the pump set on a timer and leave the speed on low except for when they need high (backwash, vacuuming, etc).
