Results 1 to 7 of 7
Thread: Adding solar to an easy touch system
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    I know this is an old thread
    Split off of this topic. Please ask questions in your own topic, rather than hijacking someone else's existing topic. JasonLion
    but I am looking to do something similar. so, to add solar to an easy touch system, I would need the above listed parts (about $300 or so?) plus some type of solar panels and hardware kit. does this sound accurate? I am currently trying to figure out pricing for a diy install.
    thanks.
    well since this post has been removed from the thread it pertained to it no longer makes sense. whatever
    Last edited by dumbcluck; 08-05-2014 at 10:15 AM. Reason: moved from where it made sense
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Adding solar to an easy touch system
    The link to the original thread is still there but what you described sounds correct. You can always call Pentair technical support to review what you have, but the thread goes into reasonable detail. I have Pentair IntelliTouch which is somewhat similar (has more capabilities, but basic hookups are similar). Take a look at p.58 in the EasyTouch manual and you will see that there are temp sensor inputs for solar (to be put up at the panels to know its hot enough to turn on) and for water (to know current water temperature) so when this difference gets large enough the solar is turned on by switching a valve to have water flow through the solar system. There is also an input for air temperature but that is for freeze protection, not for solar. For output there is a valve actuator for solar which goes to a valve that lets the output switch between bypassing solar vs. getting routed to solar. On the return side from solar is a one-way valve that allows only one-direction of flow through the solar system (i.e. it prevents the return from solar from being a way for water to flow into solar, though technically it will be blocked by actuated valve at the other end).
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Thanks chem geek. That makes sense. I'm in SoCal so don't think I really need freeze protection. So again just valve, actuator and temp sensor would do it.
    Any ballparks as to DIY cost for approx 400 sq ft of panels plus hardware?
    Apr 2013
    Sacramento, CA
    2,769
    Most of the major brand panels are sold by installers who have exclusive distribution contracts.
    You can find some on Craig's list and eBay.
    I would figure out what brand of panels you want and start searching online.
    I'd also call a couple dealers and see if they will sell direct to you.
    You also need to figure out where to place and how many. In that respect calling a couple installers and getting some bids really helps.
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    good idea gwegan. I see you have heliocol panels how many do you run to keep your pool warm?
    I found a guy who sells hc50 panels for $300 bucks each or a little more for all the mounting hardware and/ or valves and controller.
    shipping is $345 though.
    so, for a total of $2994.00 I can get 350 sq.ft of heliocol panels plus all mounting hardware and valves. everything except controller which would be another $250 I think for a gl-235 from Hayward. I have the Pentair easy touch so wont need it.
    thanks
    Apr 2013
    Sacramento, CA
    2,769
    I have nine panels on two roof faces. Five face north 4 face south. All run by jandy automation.
    If you found someone to sell them to you go for it. It is amazing how much heat they can pull into the pool
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    does that seem like a reasonable price? most places ive seen are quite a bit more expensive.
    the website is called discountsolarwaterheaters.com
