Thread: Jandy E pump won't start
    gmcnitt's Avatar
    Aug 2013
    Fort Worth, TX
    27
    I thought I posted my question earlier, but cannot find it...Anyway, this is just to help others. The 9v battery in the jandy unit died, causing the time to be wrong, programs to not run, etc....the main pump would not run. I checked voltages at the pump, found 240 v , figured the electronics failed....NOT...the problem was I did not tell the jandy unit the pump was a variable epump....once I did that its all working again. Just finished figuring out the assignments on the valves, all is good now...was within a few hours of ordering a new epump.....glad I sat back and thought about it for a few hours...
    25,000 gallons, Jandy DE Filter, Model DEV60, flow rate 150 gpm, In Ground Plaster
    Salt Water Generator (and a broken Ultrapure ozone thing if it matters)
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Jandy E pump won't start
    It relies on a 9v battery? I was going to purchase the Jandy w HP vsp..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
