Thread: Solar Heat For Pool
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Solar Heat For Pool
    I had a solar company come down, and he said my home was not capable of getting enough panels on the roof, he suggested I replace the single speed pump & motor with VSP one, and use the savings to run my heat pump to heat the water. This sound logical. Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Solar Heat For Pool
    Depends on your electric rates, what size your current pump is, and what you want to get from the solar. Even a few panels will help with keeping the water warm. I have a bigger pool than you in a much cooler climate, and 192 sq-ft of panels makes a huge difference in pool temp.
    If you could put up a few panels, you might be able to do all of your summer heating with the solar, and use your heat pump to supplement them early and late in the year. You may also consider building a pergola or some other shade structure that doubles as a solar panel rack.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I had 2 companies come out, they said save your money, the only way another company said is put them in the front part roof, which I didn't want. The motor is Pentair WisperFlo. 1.5 HP single speed. Thanks
    Autopilot SWG
