Thread: ??-On/Off switch for ic40-or timer-maybe-these my best solutions
    May 2014
    Inverness Fl
    53
    The title says it all.
    New 12K/Gal pool, w/Pentair ic40 swg that I have not started up yet. Did not want to have to buy the control unit ($) for the ic40 on top of the pool install.. Retired to Fl. to be near relatives, so we put the pool in.
    Did some searches here, the problem I have is the unit stays on (from what Iíve read), at too low an rpm: 1500. I have a Pentair VS pump, programmable for different times/speeds, but not low enough to shut the unit off for what I need the pump running at. At 750 rpm, the unit turns off, but thatís too low for the pool.
    Hereís the problem. We have a cage around the pool. It is absolutely amazing how much stuff from the Live Oak trees, gnats, pollen (weíre in country), little things you can see on the surface of the pool and I donít even know what it is, make it through the screen. Therefore, in getting used to the new pool for the last 4 months, it seems that running the vs pump like this (3 hrs in-floor cleaning system-then the rest of the day at 1500 rpm to keep the skimmer doing the surface, the bottom drain does its thing, keeps the pool very clean). But this is 6 in morning to 6 at evening, and yes we have gone nuts, using the pool off and on that much during the day, coming from Wa state.
    So, all of you that have an ic40, you know that set even at 20% run time, for that length of time, at least from what Iíve read, I will probable flood the pool with FC.
    What do you think, is an on/off switch or timer my best solution?
    Thanks
    I love this web site.
    Jan 2013
    Houston, TX
    1,079
    Re: ??-On/Off switch for ic40-or timer-maybe-these my best solutions
    I would go timer. Set it and mostly forget it.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
