Crud floating on surface of pool
BillB
0
Aug 25, 2012
107
Fort Worth, TX
My water has been sparkling clear for almost a year since I started BBB.
This morning I added 15 lbs of borax to bring it up 20 ppm.
That was about 4 hours ago.
I'm noticing what looks like tiny dull snow flakes all over the surface.
I'm assuming that is some sort of undissolved borax, at least I hope it is.
Has anyone else seen this after borating?
Thanks
A few days ago i raised my borax from 20 to 30ppm and i also noticed some white pod/bubbles on the water surface. It was after dark and they were gone in the morning when i rechecked it. I did not investigate it at the time because i reasoned that is was a side effect of the borax. They haven't returned so if it is the same it will dissipate.
That stuff is almost completely gone, today.
I'm sure it was the borax still dissolving.
The water looks like a liquid diamond with extra borax addition.
It's almost to pretty to get into.
If you haven't done borax yet, I recommend it.
