Thread: CYA question
    Sep 2013
    Gardiner, MT
    16
    CYA question
    We just got our CYA in the mail and are about to add it. I have read that people say to put it in a sock in the strainer or in front of a return (but not to allow it to touch the wall). I was going to put it in our strainer, but wanted to make sure I was understanding it correctly. The only strainer we have is srainer that goes from the hose that exits the pool to the sand filter (so hose, strainer, sand filter, it came with the filter) and then the sand filter, then the swg and then the return to the pool. I know some people have strainers in the pool or have added them to the walls. Just want to make sure I am putting it in the correct spot. Thanks for your help.
    Intex Ultra Frame 14' X 42" AG, 4000 GAL, Intex 56671EG 2,650-Gallon Sand Filter Pump and Intex 54605EG Krystal Clear Saltwater System
    30,432
    Re: CYA question
    If you know what a skimmer is, do you have one?
    Oct 2013
    Chapin, SC
    1,141
    Re: CYA question
    The flow from the return jet(s) should be sufficient to keep the sock off the pools walls.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Sep 2013
    Gardiner, MT
    16
    Re: CYA question
    skimmer vs strainer...that is where I was getting confused. We have a skimmer from our first intex pool that would could let it sit in, but not one that attaches to this pool since the "strainer" that screws into the wall doesn't have a hole for a hose (a defect in my opinion and really limits the ease of use!). Can either of you answer a question about the sand filter? My husband didn't realize I was posting here and went to put it in the inline strainer (right before the sand filter). I stopped him and he closed it back up, however, the sand filter that was running around 10 psi, is now running around 2 to 4 psi and we can't get the strainer to fill back up completely with water...is around 2/3 full, instead.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: CYA question
    A picture's worth a thousand words. Others have reported good luck sticking a pole in a ladder or something so it dangles. There's also a picture somewhere on here where someone tied the socks to a pool noodle and just let it bob around. In front of the return will probably get it to dissolve faster.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: CYA question
    And if you spend a little time wringing it like a wet wash cloth you'll get it dissolved faster.
    Solar Blanket, Well Water, Borax Added. 76
