Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Chlorine Date Code Decoder/Easy Way to Measure Strength.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Hi, I just joined TFP this season and pool is looking great. TFP is an awesome resource. Thanks
    I thought the information below might be helpful for some of the forum participants.
    I recently bought 1 jug of 10% Liquid Chlorine that was actually 4.5%. It had a 2013 date code. I now am very careful to check the date code before I purchase.
    I thought this might be a handy reference for checking bleach/liquid chlorine date codes. This decoder is for the brands that are available in my area. If you have other brands please add to this thread if you want.
    Note: Further down I show an easy way to measure the strength of your bleach/liquid chlorine.
    Bleach/Liquid Chlorine starts decomposing after it is manufactured. Check this link (scroll down) to see the half-life table (half-life means half of the original strength). Note that decomposition occurs faster for higher strength chlorine and faster at higher storage temperatures.
    Bleach/Liquid Chlorine Date Code Decoder (Year/Day of Year)
    Here is a Julian Date chart.
    Clorox
    A5 3 183 TX-1 08:41 (Day 183 of 2013)
    Walmart Great Value
    14 183 11:03 B1
    Walmart White Cloud
    14 144 12L59 B2 TX-01
    Smart (Home Depot)
    34713FL07:30
    HTH Liquid Chlorinator
    14JA0366B 11:15
    Kem-Tek
    1416210:25C
    Dollar General
    14 169 02:59 B2 TX-01
    Online Packaging Inc
    BB 07/01/15 (Date of Manufacture is 1 year prior to the "Best By:" date.) In this case Manufactured date is 07/01/2014.
    Easy way to measure strength of bleach/liquid chlorine.
    A 10,000 to 1 dilution of chlorine will result in chlorine ppm equal to its strength (percent). All you need to do is to make the 10,000 to 1 dilution, then measure the ppm using a FAS-DPD test kit. Example: If the dilution measures 8.5ppm, then your bleach strength is 8.5%.
    Step 1: Measure 1 liter of Deionized or Distilled water. Here I’m measuring 1000 grams (1 liter) of water using a kitchen scale.
    Step 2: Measure 0.1 ml of the bleach/liquid chlorine. This is easy to do by using a 0.3 ml u-100 insulin syringe and filling it to the 10 units mark (10 units of u-100 insulin is 0.1 ml)
    Step 3: Add the 0.1 ml of bleach to the 1 liter of water and mix.
    Step 4: Using a FAS-DPD test kit, measure the FC ppm (CC should be zero) of the dilution. The measured ppm is the percent strength of your bleach/liquid chlorine.
    Hope this is helpful to some.
    Last edited by epro05; 08-05-2014 at 12:44 PM. Reason: Add another Date Code Decoder (Online Packaging)
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Jun 2013
    East TN
    309
    Re: Chlorine Date Code Decoder/Easy Way to Measure Strength.
    Thats some interesting information. Instead of going through all that trouble, why not measure your FC level then put 3ppm chlorine in the pool and wait a little bit, then check to see how much your FC has risen. This would be a little more accurate when the sun goes down of course and wouldnt work if you have algae or other problems.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    You're right. I could do it that way too. But as you mentioned, the dilution test does eliminate the other variables (algae or other problems). I've seen several posts where members say that chlorine disappears as fast as they add it, have excessive loss, etc. Independently checking the bleach strength just seems like a good idea to me, just to make sure the chlorine is not disappearing because it wasn't there to begin with.
    Jun 2014
    New Jersey
    40
    Interesting. Correct me if I'm wrong, but the kitchen scale is measuring by weight where as the syringe is measuring by volume right? So, would they be the same proportionally?
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Quote Originally Posted by Big Splash View Post
    There is always somebody standing near by with a wrench ready to toss it in
    Solar Blanket, Well Water, Borax Added. 76
    38,540
    1 liter (1000 ml) of water weighs 1000 grams by definition.
    So the proportions are correct.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Gotta love the metric system.
    Isolated Spa - 345 Gallons
    Jun 2014
    New Jersey
    40
    Ah yes, but wouldn't the chlorine weigh differently than water per ml?
    38,540
    The weight of the chlorine does not matter. The point is to have the volume ratios correct.
    Feb 2014
    Central Minnesota
    5,080
    I'm unsure on what the date code on the liquid pool shock, 12.5% that I buy at Fleet Farm means.
    The code on my current bottles reads: WI-1 1440
    The next line reads: BB 07/01/15
    The outside of the cardboard box that holds the 4 jugs says SWIM SHOCK 12.5% JY
    Obviously the second line is best by the date listed but that doesn't mean much. The product is manufactured in Wisconsin so I am assuming the WI-1 has to do with it was made at the Wisconsin location, perhaps 1 being a specific line of equipment in the plant? the 1440 could mean the 40th day of 2014, which would be February 9th but then the best by date doesn't make much sense unless they have a 17 month best by criteria. I may call the manufacturer, OnLine Packaging, Inc. to see if they'll give me an answer about the date code. They JY on the outside of the box simply points to the July best by date, I would presume.
    Update: Found older bottle in the recycling bin. This one has WI-1 1226, BB 06/03/15. Box in came in is long gone in a campfire... Then the 1226, 1440 don't make sense for year/day. Safest assumption is best by date is 1 year from production date.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I spoke with Online Packaging. Your guess was correct. BB date is 1 year from production date.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by epro05 View Post
    Awesome! Thanks for checking into it.
    Sep 2014
    Los Altos, CA
    29
    OK, love the info but I just bought HTH 10% from Wallmart and the only stamping on the box is "C2274" as the lot number. Is there any way to figure out the age from this lot number?
    I would measure it in an instant with the test method but where do I get an insulin syringe?
    Also, once you put bleach into the pool does not some of it immediately combine with CYA? I have high CYA levels and cannot get my FC up and stay there.
    38,540
    You misunderstand the way FC and CYA work. You must maintain proper FC levels for your CYA level ... The CYA will not make the FC read lower.
    If you can not maintain FC levelsand have high CYA, you likely have algae in they pool and need to SLAM.
    Sep 2014
    Los Altos, CA
    29
    I describe a way to measure purchased (aged) Chlorine with a simple test kit if you do not have a syringe as described above:
    Take a used up OTO 1/2oz empty container, wash it out with distilled water several times. (you can pop out the eyedropper from these bottles).
    Fill the bottle to the brim with your specimen chlorine and put back the eyedropper top. The bottle (1/2 oz. stated will actually contain 300 drops and/or 2/3 oz. of chlorine)
    Fill a gallon milk jug or used liquid chlorine container with distilled water, making sure to fully rinse out the container several times (or buy a gallon of distilled water).
    Now put 1 drop of the chlorine specimen into the gallon jug and shake/mix thoroughly. Measure the mixture in your normal test kit way with the OTO solution.
    Because the mixture is {(1 drop)/(300 drops)x(2/3 oz.)}/128oz. or 17.5ppm of chlorine solution, if you have 10% solution you should measure 1.75ppm from your test kit.
    If you are using 8.5% chlorine, then you should measure 1.5ppm and for a 12% chlorine solution you should measure 2.1ppm chlorine.
    I know this is only approximate depending upon the OTO test kit color recognition, but at least it will tell you how potent, roughly, your chlorine specimen is.
    You may do better with a DPD test kit using titration.
    Sep 2013
    Connecticut
    728
    Quote Originally Posted by Thehobe View Post
    This misunderstanding showed up in your other thread, and was addressed there also:
    http://www.troublefreepool.com/threa...880#post734880
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Can you use purified water instead of distiller water to do this?
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    38,540
    Should work. The idea is for the extra water to not have any chlorine or CC in it like tap water usually does.
    Although in reality, there is not much point to doing this test as the errors can be pretty large.
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Thanks Jason!
    Lisa
  20. Back To Top    #20
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Is there a phone app that you can just type the number and it will show you exactly when the bleach was made?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
