Results 1 to 7 of 7
Thread: SWG for AGP?
    Jun 2008
    Marana, AZ
    347
    SWG for AGP?
    I was wondering about the feasibility for an Intex or some other low cost salt water generator for my pool. My pool's about 9400 gallons. Since it's a soft side AGP, not all SWG's can be used with it, nor do I really want to spend a whole load of money for an SWG. So you people that have Intex or other low cost SWG's, are they worth it? Do they hold up, and would they really be able to take on a pool of that size?
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Nasty90's Avatar
    Apr 2008
    48
    Re: SWG for AGP?
    This unit works for 18,000 gallons... for 150 bucks.
    35000 in ground vinyl liner with cartridge filter
    Birmingham,AL
    Re: SWG for AGP?
    I believe that Nasty90 is talking about the Chlorease, which is discussed in this thread.
    The Intex SWG is also in the same price range. It is discussed in this thread.
    The AquaTrol, more expensive than either of those, is a popular SWG for above ground pools with some additional features.
    JoshU's Avatar
    New Orleans, LA
    543
    Re: SWG for AGP?
    I don't believe the ChlorEase unit can be installed on a "Soft Pool". As far as I know it still can only be installed on pools with top rails as it needs to clamp on. Please correct me on this if I am wrong.
    In addition to the other offerings mentioned above the Cubby Plug 'n Play from AutoPilot doesn't require any plumbing work to be done. It just simply floats in the pool.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: SWG for AGP?
    I've got the Intex SWG hooked up to my 24' AGP (approximately 13,500 gallons), and I love it. It keeps my FC around 5ppm on 6 hour run time. The controls are somewhat limited, but that's to be expected for the price you pay for the unit.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Jul 2008
    South Eastern PA
    40
    Re: SWG for AGP?
    I just wanted to point out that the Chlorease is not self cleaning and needs to be cleaned regularly (monthly I believe).
    8200 Gal Vinyl 18' AG Vogue Pool
    150lb Hayward Sand filter with 1-1/2 HP Maxim Pump
    Intex SWG
    Some of the most helpful links for pool owners: Pool School | Pool Calculator | The best test kit | Chlorine/CYA chart
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: SWG for AGP?
    Quote Originally Posted by jugger2500
    You are correct. I actually had the Chlorease unit last year. Kind of a PITA to clean, too. It's a passive over the rail unit that relies on the circulation of the pool to spread the chlorine, whereas the Intex unit is plumbed inline with your pump/filter, and chlorinates the water being returned to the pool.
    Intex 8110 SWCG
    "Fear the Schnauz!"
