Results 1 to 10 of 10
Thread: HTH Clear All Power pods
    Aug 2014
    Murphysboro IL
    4
    First off, I'm not sure what is going on this year with regards to my pool. I've owned my 28' AGP for 4 years. This year it seems every week my pool gets cloudy and turns green. I've tried to keep my levels right but doesn't help much. Here's the thing, it looks green, but if I turn the pump off all of this yellowish/greenish "powder" falls to the floor of the pool, leaving the water perfectly clear. So, I vacuum to filter but all this does is float this powder back into the pool the filter does not catch most of it. Now to be up front, I have trees all around my pool in the back yard, large trees. This has not happened in the years prior with this pool....
    SO, I saw this product at Wally World and decided what the heck I'll try it... This pool is larger than 10,000 gallons so I used 2 pods. Within 3 hours there was virtually NO output of water back into the pool. So I back washed it. I couldn't see any green, yellow or any other color coming thru the sight glass so I put it the valve back to filter. Water pressure is back to normal, but I only back washed for about 30 seconds or so...?
    I don't know if my problem is pollen or what but it sure is frustrating. Btw way I am using a brand new this year sand filter and pump. I typically do not use the brand name stuff, I use bleach, backing soda, myuratic acid. I've always been able to maintain a virtually a clear pool until this year but our weather has been much different than years in the past.
    Aug 2014
    Murphysboro IL
    4
    Re: HTH Clear All Power Pod used, now filter is clogged, will it eventually dissolve?
    I tried these yesterday. Did the same to my sand filter. Backwashed for 30 seconds, pressure back to normal...? My pool is cloudy but it isn't chemical related, I think it's pollen (my pool is surrounded by large trees). The sand filter will not filter this stuff out. The only thing I've found that works is the leave the pump off for two days, let it all settle to the floor, the vacuum to waste then I have clear water again. I have to do this once a week this year. This has not been a problem for the last 4 years.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: HTH Clear All Power pods
    Glad it worked for you, but we generally don't advocate putting anything in the pool that we don't know what it is or what it is doing. The MSDS for this product lists the chemical as "proprietary" so it wouldn't go in my pool. Do a search here and you will find complaints of clogged filters.
    Support the site
    Aug 2014
    Murphysboro IL
    4
    Quote Originally Posted by tim5055 View Post
    I should be more clear (pardon pun) but it hasn't worked for me yet... It just stopped up my filter until I backwashed.. It's still way cloudy..
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by jimmyv01 View Post
    Oh, sorry I misunderstood.
    This is why we don't like magic potions, they usually just magically move money out of your wallet.
    Support the site
    Donldson's Avatar
    NW Ohio
    2,881
    Would you mind sharing your latest test results and the method to get them? The vast majority of time cloudiness is a chemical problem rather than a mechanical problem.
    I have a link in my signature to the Pool School, within that is the ABC's of water chemistry. Reading that will help you understand some of the advice that will be given here.
    And welcome to TFP!
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    +1^^^^^^^ 😎
    Jeff
    Aug 2014
    Murphysboro IL
    4
    Quote Originally Posted by Donldson View Post
    And welcome to TFP!
    I've learned a lot from this forum over the last four years.. My chemical composition is fine. My cloudiness is being caused by something floating in the pool, something too small to be caught in the sand filter... This is proven every other week when I shut the pump off for two days.. The water is crystal clear with some powdery stuff on the bottom. I'll upload a picture of the pool after I've vacuumed 1/2 of it.. 1 side is green the other side crystal clear.
    Mar 2007
    San Rafael, CA USA
    12,082
    Pollen varies in size from 2.5 to 200 microns with most being around 25 microns. So some will get easily filtered by a sand filter and some will not without assistance. You can see if following the Pool School article Add DE to a Sand Filter helps. You may have a different cause for the cloudiness so if you post a full set of water chemistry numbers we might be able to help.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    We're still going to ask to see test results and how you obtained them. Just saying your chemical composition is fine is not what we like to hear. The proof is in the pudding. You should be proud to show us that you water composition is fine. I'm not trying to be offensive ! We base our advice off accurate test results.
    You say one side is green. Are you saying you have algae ?
    You can also add some DE to your sand filter. That may help with filtering the stuff out.
    Adding DE To A Sand Filter
    Here are some good articles to look at.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool
    Welcome to TFP !!😎
    Jeff
