Results 1 to 7 of 7
Thread: steps to take when leaving pool for a week
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Just wondering what you all do and if there are any special steps necessary to take when leaving your pool for around a week? Lets assume there is a solar cover and timer on the pool.
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Orlando, FL
    690
    Re: steps to take when leaving pool for a week
    I bring it up to shock level and it is fine. However, someone with more experience should come along soon and provide more guidance.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    What is your CYA level ? Bring FC up to shock level and put some pucks in a floater if you have room for CYA. Leave cover on it.
    Other option is have somebody look after it. 😎
    Jeff
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Cya was about 25 the other day when I checked it. I can put some pucks in the chlorinator.
    Oct 2013
    Chapin, SC
    1,141
    How long does it take your pucks to dissolve completely, and how many can you put in? When I was using bleach, I poured a jug of bleach in just before I left and put as many pucks as I could fit in a floater. When I came back 10 days later, my FC was still 5ppm and I had a bit of the tabs left as well. Probably could have lasted another few days.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,025
    You're in great shape if CYA is only 25.
    I raise the water level a couple inches to allow for a lot of evaporation, so I don't run the risk of running the pump dry and frying it, and then I pack as many pucks into the floater as I can. If you break them, they'll dissolve faster and you can also sometimes fit more in.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Quote Originally Posted by pwrstrk View Post
    Other option is have somebody look after it. ��
    EXACTLY what I'm doing this week. Will also have a friend make two 1 gallon bleach additions on Tues. and Thurs.
