Results 1 to 8 of 8
Thread: 150lb Hayward Sand filter w/a 1.5HP motor overkill
    I have an 18' x 48" Intex Metal Frame (roughly 6,000 gallons)
    I have found a 2 year old Hayward 150lb Sand Filter (has brand new sand in it as well) with a 1.5HP pump locally for $100.
    Is this going to be overkill for my pool, will I have problems with it having too much power for the pool?
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: 150lb Hayward Sand filter w/a 1.5HP motor overkill
    It may or may not be overkill but for that price I'd get it.
    You could always sell the motor on Ebay and just put a 3/4 or 1 hp motor on that filter.
    Look in my sig for what I use as a motor, I got it for $99 shipped on Ebay and it came with a strainer basket too.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    Wyoming, Michigan
    93
    In my opinion, the pump to filter size is more of an issue than the pump to pool size. Filters are rated for a max flow rate based of the surface area of the sand. With an AG pool, there is not normally the same amount of head loss in the plumbing that one would see with and IG pool. Because of this, its very possible that with that motor/filter combination you could very well be above the designed flow rate for the filter. You could remedy this restricting the return back to the pool some (either a smaller return, or a ball valve partially closed), but you still will be paying the electricity to run a 1-1/2 HP pump (OK, a little less with the reduced flow, but still probably more than a 1 HP would cost to run).
    Do you know what size the filter is (diameter)? The typical designed flow rate is 20gpm/ft2. Here is what that works out to for different filter diameters:
    • 18" - 35gpm[/*:m:i222hjrr]
    • 20" - 43gpm[/*:m:i222hjrr]
    • 22" - 53gpm[/*:m:i222hjrr]
    • 24" - 62gpm[/*:m:i222hjrr]
    The other factor that could be mentioned is turnover rate. Normally people shoot for 1-2 turnovers per day. With a higher flowing filter/pump combination, you could potentially be turning over the water very quickly. It probably isn't a good idea to complete a turnover in 2 hours and then leave the pump off the rest of the day (stagnant water is usually bad), but running for longer means your getting more turnovers with potentially diminishing returns.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    If I may chime in here with a question as well. I am about to purchase a 2-speed Pentair Dynamo to lower our electric bill. We have an 18" SD40 sand filter (with zeolite) and 1.5" piping (actually, it's still the tubing right now - until we hard-plumb it). We're currently running a 1hp Pentair Dynamo and really like the Dynamo.
    Our situation is that, in addition to wanting a 2-speed pump, we will be adding a 2nd return in the shallow end to help with circulation. So would the Pentair 2-speed work for us? From what I've researched already, it looks like it would. BBBUUUUTTTT, my niece tells me that her store sells a 1.5 hp, 115 v., Pentair Dynamo 3-speed! I can't find one online and she hasn't called me back yet today.
    If she was mistaken about the 3-speed, this post will be moot. However, if there is such a Dynamo, will that work for our pool as well, or should we just stick with having her order us a Pentair Dynamo 2-speed? Her 1.5 hp could well be an uprated model - don't know, since I can't find it online (while waiting on her to call me back). If she DOES sell a 3-speed, I'm thinking that the middle speed would be better for us, if we're going to add a 2nd return line, which, in my understanding, will add to the resistance flow.
    Any info would be appreciated! Thanks.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Dec 2007
    Central New York
    504
    Here is the Dynamo pump manual. It list a 2 speed wih a 3 foot cord.
    http://www.pentairpool.com/pdfs/DynamoOM.pdf
    All Dynamo pumps listed on Pentair's web site
    http://www.pentairpool.com/products/products3.php?id=46
    Pentair and Sta-Rite pumps (same company)
    http://www.pentairpool.com/products/products2.php?s=44
    Sound like you have one of these pumps and want to go to one of the other pumps listed.
    ttp://www.poolcenter.com/pumps_pacfab_dynamo.htm
    Sorry, all I could find.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Thanks for the links HodRod. I'll look them over tonight, so I can be more informed when (IF) my niece gets around to calling me back!
    Wyoming, Michigan
    93
    Quote Originally Posted by Cherie
    ...we're going to add a 2nd return line, which, in my understanding, will add to the resistance flow.
    No. Adding another return will LOWER the resistance to flow. It's the same as increasing the pipe and return nozzle size. The volume and speed of the water coming out of the return will be reduced since now its split between two returns. I would expect to see the pressure gauge on your filter drop some when both returns are open. By making it easier for water to return to the pool, I would also expect your flow through the filter to increase slightly as well.
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Thanks for the info, Tom. I did, indeed, have that backwards, didn't I? And here, after all that reading, I thought I had it down!! My brain is almost jello from all the studying on how to take care of our pool - and trying to get better circulation.
    We're waiting on The Circulator, which will hopefully arrive one day this week. So our hope is that, with The Circulator going and running a 2-speed on low 24/7, we will have a lower electric bill with better circulation. We'd really rather not have to add a 2nd return.
    Thanks again for your help!
