Results 1 to 8 of 8
Thread: Clorox now makes pool chemicals...
    Jun 2012
    Howell, NJ
    977
    I was looking on Amazon for a cheap test kit (to test my well water pH, not my pool [but, that's a whole other story]) and I noticed a banner advertising Clorox pool chemicals. I expected to just see relabeled bleach, but no, they went all the way. They have solid chlorine, algaecide, clarifiers, everything. I have to say, I just lost some respect for Clorox. Chlorine/Here's their whole range of products.
    Does anyone know how long this stuff has been around? Also, it should be noted that, at least on Amazon, I don't see any Clorox "Liquid Chlorine."
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: Clorox now makes pool chemicals...
    Clorox does have "Clorox Pool and Spa" which is 10% liquid chlorine. I saw it at Lowes.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,029
    I saw it at Lowes too.
    Divin Dave,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    This topic came up a few months ago, as it turns out Clorox is just licensing their name out to 3rd party that makes the stuff.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,029
    Ahhhhhh,
    well the Clorox I saw at Lowes was close to 4.50 gallon. It was right beside the Kem-Tek 10% chlorine for 2.85 gallon. Thats a pretty expensive label if you ask me.
    Quote Originally Posted by Isaac-1 View Post
    Divin Dave,
    Jul 2014
    Toledo, OH
    49
    Quote Originally Posted by Divin Dave View Post
    Ahhhhhh,
    Never thought about Lowes for liquid chlorine. Nearby Meijer store has 10% for $12.49 a case ($3.12/gal).
    I've gone out to look for myself. If I return before I get back, have me wait for me.
    16x32x8 Fort Wayne Elite Polymer IG with vinyl liner and 8' acrylic end steps. Hayward S-200 sand filter with 220 VAC Super Pump and VariFlo valve. Installed in 1988.
    Jim
    Jul 2014
    Toledo, OH
    49
    Ahhhhhh,
    Just came from our nearby lowes. no Clorox pool products nor Kev-Tek.
    Jim
