Results 1 to 8 of 8
Thread: I have a hose bib on pipe between pump discharge and filter. What is its purpose?
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I've had this pool for 20 years and still don't know why there is a hose bib installed between the pump outlet and the filter.
    Can someone please tell me it's purpose?
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Re: I have a hose bib on pipe between pump discharge and filter. What is its purpose
    maybe to hook up a pressure gauge??
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Could be. But the the pipe with the hose bib goes to the filter, which has its own pressure gauge.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Hook up a hose there to drain the pool?
    Support the site
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    I do have a suction line for my Kreepy Krauley. If I set the valves to not draw from the skimmers, and only draw from the Kreepy, then position the Kreepy at the deep end, I think that would work to drain the pool. Maybe that's why the bib is there.
    Thanks for that insight.
    Jun 2014
    860
    I have a hose bib on pipe between pump discharge and filter. What is its pur...
    Some installers will add that bib there for pressure testing the plumbing prior to gunite. My PB installed a hose bib in that exact location and he asked me if I wanted it taken out. I told him I'd keep it.
    It can be useful for slow drains while you let the equipment run. Since the hose bib is relatively small compared to the piping in the rest of the system, there's very little pressure loss. I've used it for doing slow drains (~5 gal/min flow rate through a standard garden hose) and I find it useful for bleeding air out of the piping that gets trapped when I open up the pump basket.
    Mine is plastic so I suspect it will eventually start to leak. At that point I'll either remove it or replace it.
    Also for filling a dry pump before priming. Pool techs sometimes carry a short hose with two female ends to do this.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Good information. Thanks, appreciate it.
