Thread: Ch creeping up in the last 5 months?
    May 2012
    Flower Mound, TX
    130
    Today test results.
    Temp: 83
    FC: 7.0
    CC: .5
    PH: 8.0
    TA: 90
    CH: 520
    CYA: 45
    Borate: 50
    CSI: 0.57
    Water is crystal clear, I add muriatic acid once a week to keep PH at 7.5, it likes to settle around 7.9-8.0 But my concern is why CH gets higher and higher. I test CH once a month. On May 1st CH was 340, Jun 1st CH was 400, Jul 1st CH was 420, now its 520.???
    I don't add any calcium products, only 32oz. of bleach once a day & 45-55oz of muriatic acid once a week. My home faucet water tested CH:70ppm. My guess, CH is coming from topping off pool every other day.
    With CH that high, I need to keep PH on the low side to balance CSI at zero. But once again, my water is clear with the very high CH.
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Jun 2013
    East TN
    309
    Re: Ch creeping up in the last 5 months?
    You guessed it. Water evaporates and leaves the calcium behind amongst other things. Then you fill the pool back up adding more calcium. Even a low CH fill water will still add to it over time. If the water is clear and you have no scaling then I wouldnt worry too much about it yet just be prepared.
    You could run some guttering to the pool to catch rainfall to dilute it if your not wanting to drain and fill. The more rain the better but if you dont get any that wont help. The rain/guttering will also dilute your other parameters also.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
