Thread: Weekly Test Values
    Question Weekly Test Values
    I have been using the K-1000 and TF-100 for weekly testing and decided to take a sample to my pool retailer who is knowledgeable about pools and chemicals. Their results were not even close to what I have been getting with my kit. My numbers FC 2 Alk 70 cal. 240. Ph 7.8 and CYA. 52. Compared to FC 0. Alk 12. Cal 800+. Ph 7.8. And CYA 50.
    I went ahead and adjusted the alkalinity based on the 70 to a target of 90 and will retest in a few hours. Should I disregard their readings altogether? I am using new reagents except for the calcium, but have noticed dime to quarter size raised spots that could be calcium deposits.
    Pool is clear and no algae problems all season. Have a liquidator and in line tab chlorinator set at 1. Use poly quat 60 and clarifier weekly and pool size is 35k gallons.
    Thoughts?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Weekly Test Values
    Yes disregard the stores testing. Trust your own testing !
    Your FC is low for your CYA. you should be targeting an FC level of 8 and never below 4.
    If you have a liquidator why are using an inline chlorinator ?? Also if you maintain the proper FC levels there is no need for the polyquat 60 or clarifiers. I suspect the reason you don't have algae is from the use of polyquat. Not because your FC is in range 😎
    Jeff
    30,431
    Re: Weekly Test Values
    Either theirs or ours. That's why sports teams only have one manager. You will never get your pool clear listening to 2 sets of instructions.
