Thread: How much and how to add Purifiber?
    georgiadawg's Avatar
    Jul 2014
    Eastanollee GA
    93
    In my posts on getting my pool clear, Purifiber was suggested for my cartridge filter. I read the instructions from that post, but it didn't tell me how I know how much to use for my pool. The bag doesn't list my type of pump/filter either and I couldn't find anything in the manual that tells me what my "*Effective Filtration Area" is.
    I don't even know where to start with this. The pump is SFS1000 Filter System with F1500C Pump, whatever that means. It's a cartridge filter.
    Lisa
    Northeast Georgia Pro Series above ground circular metal frame set pool 22' x 52". 11,400 gal capacity. w/ Skimmer plus 2000 pump/filter. Cartridge filter (Type C)
    Intex Krystal Clear Saltwater System Model CS8110
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: How much and how to add Purifiber?
    Do you have a pressure gauge? I think you add enough to bring up 1 psi, then clean as normal after you get a 10-15% pressure rise.
    Here are directions on adding to the different kinds of filters.
    http://www.fiberclearpoolandspafiltr...structions.pdf
    Jul 2014
    Eastanollee GA
    93
    No, no pressure gauge.
    Okay, I looked at the directions on the link. But, it doesn't help me. Because I have no idea what the filtration area is for my pump. That's my original question. I think I can figure out the application, but until I figure out HOW to figure out the amount to apply, it doesn't help me. Does anybody understand what i'm asking? I'm trying to be very specific.
    Lisa
    Jul 2014
    Eastanollee GA
    93
    Can anyone help me with this?
    Lisa
    Apr 2011
    Murrieta, CA
    2,360
    Here's the manual (Check page 9).
    http://www.genfoam.com/manuals/2009%...l%20Manual.pdf
    It appear to be 7 feet of filter material.
    8” FILTER CARTRIDGE 7 SQ. FT 090-130011 10.00
    38,361
    wow that is a tiny filter. I did not know they made them that small
    FYI, for a 5k gallon pool, I would recommend a filter at least 50 sqft.
