Thread: Alkalinity Tests and more
    Jul 2014
    Northern Minnesota
    51
    Did my first Alkalinity test this morning. Did it twice. First reading was 190ppm. Second was 220ppm. Our other results:
    FC 5+
    CYA 35
    PH 7.5
    Our water is crystal clear. Any thoughts on the high alkalinity?
    Intex 15 ft x 42" Above Ground Pool bought from Amazon (3, 284 gallons)
    Standard pump and cartridge filter that came with the set up (1,000 gph)
    I live in Northern, MN
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Alkalinity Tests and more
    As long as the pH stays relatively stable, ignore TA.
    You might have static electricity on the tip of the R-009. Try wiping the tip with a damp paper towel between drops.
    Mid Missouri
    227
    In your case TA is not something you need to particularly worry about in and of itself. But because yours is that high it's just a predictor that your ph will have a tendency to rise and require periodic acid additions. How fast it rises will depend on how much aeration occurs. When your ph reaches the point where you want to adjust it, having the TA in the pool calculator makes the ph adjustment more accurate.
    Also knowing the TA of your fill water lets you know if you ever decide to go to a SWCG for your chlorine you'll be making frequent acid additions, particularly early in the season, to keep your ph in line and to bring your TA down. Which is what I have.
