Thread: First time SLAM'ing have questions
    Mar 2013
    Hendersonville, TN
    9
    My pool has been great all year by staying on top of it. We went away for 9 days and used the floating puck method to try and keep the pool somewhat clear. I kept my CYA generally between 40 and 50 and when we returned I had algae and the pucks brought my CYA up around 80. I did a partial drain and started slamming two days ago. The pool is now just cloudy looking but I did have to brush a minimal amount of algae off the floor this morning. My current numbers are as follows:
    FC 20
    CC .5
    TC 20.5
    PH 7.8
    TA 90
    CYA 60
    Based on the chart I have been bringing the Chlorine up to 24 over night. This morning it has dropped to 20. I will add it back up to 24 but if I wait a few hours, would it be safe to swim? I may even drain a little more water first. I have my nieces and nephew visiting for the weekend and that is all they want to do.
    Last Year: Pro Series Frame AGP 16' x 48" Approx 5,060 Gallons. 1500GPH pump, Cartridge filter in skimmer. TF-100 Test Kit
    Just Built 5/7/15: Doughboy 24' x 54" round above ground pool 16,000 gallons. Astral Pool 22" sand filter, Waterway 1 1/2 hp 2 speed pump. TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: First time SLAM'ing have questions
    Safe to swim up to your SLAM level for your cya which is 24.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    What Woody said, but.....not safe if the cloudiness means you can't see bottom. That's just for safety.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2013
    Hendersonville, TN
    9
    Thank you for the responses. It never got cloudy enough to not see the bottom so I guess I'm good.
    Jun 2014
    Wesr Chester, Pa
    1
    Good Luck
    16x37 IG 50 year old 25,000 gal plaster
    DE filter,1.5HP pump
    280 polaris cleaner
    West Chester, Pa
