Thread: Help!! Frothy bubbles on top of water
    My grandchildren got an above ground pool again this year. I thought I would install a saltwater system so the water would stay clean this year. I also installed a more powerful pump. The problem is when I run the saltwater system. Yellowish frothy bubbles form on top of the water and sit there. I can scoop them off and as long I only run the regular pump, they will not form, but if I turn on the salt generator back on they begin to form again. I thought it might be because the PH was too high, so I lowered it, and it has not made a difference. The pool water comes from a well, I don't know if that has any effect.
    Can anyone give me some advice?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Help!! Frothy bubbles on top of water
    So that we can give you better advice, can you please post a full set of test results and also update your signature to include your pool equipment and specs.... Go to "User Control Panel" (top left) and then "Profile", and then "Edit Signature".
    Welcome!
    Mar 2007
    Coastalish 'down easter'
    4,160
    DGTURNER221 - welcome to TFP!!
    Did you add any non - polyquat algaecide to the pool? The reason I ask is because some of the other algaecides will foam in salt water
    Please do get the test results that FPM and post them for us (and also if and/ or what kind of algaecide you've used)
    Luv& Luk
    -Ted
