Thread: Help with Algae
    May 2014
    Cottage grove, wi
    6
    Help with Algae
    Please do not hijack another poster's thread. Start your own thread so you can get the help you need.
    Not sure if the little bit of green algae I had is gone and now I'm nervous to go in my pool. I saw some very light green in sporadic areas of my pool. I shocked with bleach. The next day I saw no tint of green and my pool water is clear. I am not sure if i have gotten rid of it or not. I have no real good way to clean my pool other then a Syphon system my husband uses to clean his fish tank water and a Intex system that uses your garden hose and I haven't been in my pool for a few weeks either due to crappy weather. Anyway do I just do the overnite chlorine test and if that suggests no algae is it safe to swim. I have two young children that want to go in so bad.
    2200 gallon intex 12ft round inflatable ring temp pool
    Intex pump that I run 24/7.
    3rd summer
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,078
    Re: Help with Algae
    Hello, and welcome to TFP!
    The one advantage you have over a large amount of members on the forum is the ability to drain the pool without a major cost or risk of damage. At this point if the waters clear......go swimming! Worse case says if it turns green, a quick drain/refill will have you up and running again.
    See the Guide for Seasonal Pools for more details on dealing with your pool.
    Welcome to TFP and we hope your little ones enjoys the water this weekend.
    Jan 2013
    Houston, TX
    1,079
    Re: Help with Algae
    Can you post a full set of test results for us?
    The OCLT will tell you if there is something consuming your chlorine. It is usually done at slam levels.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
