Thread: Intex Ultra Frame Pool 32 x 16 x 52
    Jul 2014
    Georgetown, Ga
    6
    I am getting an Intex ultra frame pool 32 x 16 x 52. We found it on Amazon with salt system included for $1290 shipping included. We will not be putting it up until next spring around March. We have a friend with a construction company leveling the area for us for free (thank God for friends!) My question is I found the demensions on with the leg supports out as 17'10" by 34'. Here is a link to the chart http://www.poolproducts.com/SPP/dept.asp?dept_id=3086. My question is going off this chart what is the exact area I need to level? I know people keep saying give so many feet on all sides. I want to know exactly please if anyone knows. Looking at the picture it is from the corner to the supports on one side so if it is 34' that is 2' for one side so I have to add 2' for the other side too right? Also the other side is 17'10" so same question do I need to add 1'10" for the other side too? By my calculation I would need 36' x 19'8" is this right?
    jmcdtucson's Avatar
    Jun 2014
    317
    Re: Intex Ultra Frame Pool 32 x 16 x 52
    The outer width appears to be the entire outer width. Which makes sense, I can't imagine they meant the pool plus only the supports on one side.
    I just measured my width (24x12 pool) and it's 13'10" which is exactly what the chart shows for the 24x12.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    May 2014
    LA, USA
    16
    Info from my install that may help.
    http://www.troublefreepool.com/threa...2-quot-AG-Pool
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Rayeanne Hopefully it won't be long until you are
    Since you're getting the pool you could go ahead and add it's info to your "signature" as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 68
