Thread: Cannot stablize chlorine level
    Aug 2014
    tampa,fl
    1
    It does not matter how many bags of shock that I use the chlorine level will go up for a day or so and then back to zero. I also have a chlorine feeder that feeds 3 to 4 tabs (3 inch) weekly. The pool itself looks beautiful. I have been multiple bag shocking the pool for 6 weeks. Initially there were orange stains which the shocking did clear up but there are white small floaters that have not filtered out. The pool store owner just keeps telling me to shock, shock, shock but it does not seem to be working. Any suggestions would be greatly appreciated!!!!
    My pool chemical results are as follows:
    1. free available chlorine 0
    2. total available chlorine 0
    3. calcium hardness 450
    4. cyanuric acid 50
    5. total alkalinity 80
    6. PH 7.4
    7. copper 0
    8. iron 0
    9. total dissolved solids 1200
    10. phosphates 100
    38,267
    Re: Cannot stablize chlorine level
    Welcome to TFP!!!
    You need to stop listening to the pool store and stop trusting their testing. The path you are on is likely making your problems worse.
    Start your journey to understanding in Pool School by reading these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    You are then going to need to invest in one of the Recommended Test Kits so that you KNOW what is going on in your water.
    This is not as hard as it initially seems and there are 100s here willing to help.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Welcome to TFP!
    I'm suspicious that your CYA is as low as 50ppm. Tabs increase it rapidly and you get into situations like you have where the chlorine just can't fight what is in the water because of the CYA.
    Check out ABC's of Pool Water Chemistry, then read SLAMing Your Pool
    You'll want to stop using any form of powdered chlorine and the tabs, because it all adds CYA or calcium, and you are at high enough levels for those already.
    Our method is like a sniper, while the pool store advice is like firing a shotgun blindly and hoping you hit something.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Welcome!
    There is a lot of learning ahead. It's a steep curve, but then you just coast. One thing you must understand is that your pool is like a living creature. It has its own personality and its own appetite and it needs to be fed every day. You can't fast for 3 or 4 days and then catch up at the all-you-can-eat buffet.
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome to the forum!
    Quote Originally Posted by JohnT View Post
    ^^Best quote I've seen around here in a long time!!^^
