Thread: When to run the filter
    Jul 2008
    Seacoast, NH
    250
    Is it better for the pool to run the filter at night or during the day, or does it matter? Of course, if my area is ever under an energy shortage like happens where I used to live, I'll run it when they tell me it is best to run it.
    19,000 gallons, Well Water
    Stay-Rite System 3 Cartridge filter
    IG vinyl, MasterTemp 400 Propane heater
    Intellichlor 40 SWG, 2006 Taylor Test Kit with Speed Stirrer
    1.5 HP Pump
    Re: When to run the filter
    It is just slightly better to run the pump during the day. But if you have time of day electrical rates, the cost savings makes it worth running at night.
    Jul 2008
    South Eastern PA
    40
    We have time of day rates so we run our pump 3 hours from 9pm - 12am, 3 hours from 6am - 9am, and then four 15 minute intervals spread throughout the day to keep the water circulated.
    8200 Gal Vinyl 18' AG Vogue Pool
    150lb Hayward Sand filter with 1-1/2 HP Maxim Pump
    Intex SWG
    Some of the most helpful links for pool owners: Pool School | Pool Calculator | The best test kit | Chlorine/CYA chart
    Dec 2007
    Central New York
    504
    When you hook-up the SWG, you'll have to adjust the run time of your pump.
    Every pool is different, but you'll get hang of what your pool needs during times of weather, pool load and what your test results show.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
