Results 1 to 11 of 11
Thread: pump troubles
    pump troubles
    hey all.
    this morning i went outside and i could hear our pump running loudly but there was no flow. we had heavy rain last night and there was a lot of junk in the strainer and skimmer baskets unfortunately. i got everything cleaned out, but i can't get the pump to move water again. i also found a lot of small black pieces that look like plastic in the pump strainer as well as the skimmer baskets....not sure if it was runoff from something or the pump internals have disintegrated.... but anyhow. unfortunately this clogging has happened to me a couple of times over the time we've been in the house, which i know is bad for the pump but i can't do anything about that now.
    my other problem is i can't quite figure out what i have, but it seems to be old (this owner's manual was from the 80s). we only moved into the house a year ago, but the previous owner left me this owners manual:
    this is the label off the motor, so i know i've got one of the four 1.5HP models but unfortunately the pump label is missing.
    any ideas or tips to figure out if my pump is toast? is it worth trying to rebuild? typically it primes up on its own no problem after a few seconds, but this time it isn't doing that anymore. when i switch the pump back off it is making a different whirring sound than it usually does so something does sound amiss.
    thanks in advance.
    happyheathen's Avatar
    Sacramento CA
    225
    Re: pump troubles
    First, find the PUMP mfg label - the label you have is the motor's (A.O. Smith seems to own the pool pump motor market).
    Then: find out if replacement parts are available.
    Then find a video of how to open it enough to get to the impeller.
    Then, if parts are available, decide if a paert needs replacement. If it does, and the part isn't available; well, I wouldn't bother re-assembling it.
    I'm assuming you've checked the baskets (not usually black) for missing pieces.
    The other possibility is some foreign object got ground up by the impeller - are the kids missing a black plastic boat?
    There was a 6" gap in the fence when I moved in - the next door kids decided to see if they could throw a toy far enough to get in the water. They couldn't maybe yours?
    Good luck!
    p.s. Adding your pool info to your signature block is not only a recommended prratice, it is really handy.
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Re: pump troubles
    Maybe its just sucking air and not priming? Pumps get pretty loud if they are sucking air. Just thinking you could eliminate that possibility before tearing it apart.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Re: pump troubles
    The pump label is missing unfortunately, as I said above. No kids, and no toys made it in.
    As for no prime, it typically self primes on its own just fine. But I did fill the strainer with water to try to give it a boost and it didn't help.
    Re: pump troubles
    I wouldn't put too much effort in to it. If the pump is that old, it doesn't owe you anything. Just gives you an opportunity to upgrade to a more efficient one.
    More than likely you're going to be nickeled and dimed to death with on going issues.
    Just make sure the rest of the plumbing and components are ok.
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: pump troubles
    You can take it apart to inspect the wet end. If it looks in good shape, keep it and replace motor only - plastic parts on the wet side with good care "should" last forever. However, if the chemistry was in doubt and the plastic got brittle, I agree with the sentiment of not getting nickle and dimed. Replace the whole thing with a 2 speed, and you can make the new, efficient pump last a long time.
    Re: pump troubles
    alright. yeah, i'll see what i can inspect tomorrow but i think you're right - it probably gives me a good opportunity to buy something more efficient.
    i'm still a newbie when it comes to pools, only having owned this one for a year. is replacing a pump something relatively straightforward to do? or should i go ahead and get someone to come do it for me?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: pump troubles
    Rerouting the plumbing and finding the correct adapters is the hardest part. In terms of DIY jobs, probably the easiest to learn if you're willing to do a little research.
    Jul 2014
    Peoria, IL
    389
    Re: pump troubles
    I just had the wet end of a pump on my spa seize up. After doing all of the research I replaced the whole shooting match. Pump and wet end. Not worth doing part on an older motor like that.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Re: pump troubles
    well, after further inspection the impeller is cracked. so that explains the no flow
    will try to get it up and running tomorrow after i find a replacement part.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: pump troubles
    Good job. Your pump replacement job ($hundreds$) just turned into a fast part replacement ($25).
