Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Is Clarifier only for cloudy water?
    Wildcat's Avatar
    Jun 2013
    309
    For weeks I have been trying to clear my pool of a lot of particles. Pool is not cloudy, just a lot of small but not microscopic particles, some brown life leaf particles but mostly translucent ones. Have run pump a lot of extra time.
    Will a clarifier help with these particles? They are not small as much as they seem so light they just float in place and never get filtered. If a clarifier is the answer, is Seaklear the one to use?
    I have a cartridge filter if that is relevant
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
    Casey's Avatar
    SW PA
    10,453
    Re: Is Clarifier only for cloudy water?
    Clarifier will do nothing for this particular issue. Brushing the pool will by getting the particles in suspension and filtered out.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Just curious, how does the pressure behave on your filter?
    Essential Links:
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by Casey View Post
    I do brush, almost daily. The particles are in suspension but seem so light they are not pulled into the skimmer. Or about the same amount is coming in as is going out!
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by Brushpup View Post
    Not sure what you are asking but I cleaned my filter a couple of weeks ago. Though not extremely dirty as I had done it a month before that, it was picking up sand and other materials like seeds and small particles.
    My filter is large for my size pool. Pressure had not moved up much, if at all in the last two weeks. I doubt filter is clogged or is being bypassed. New filter and pump a year ago. Easy to track pressure rise as it has. green indicator arrow for initial pressure and a red one to help indicate it is time to clean. Barely moved off the green one.
    Wildcat's Avatar
    Jun 2013
    309
    As I continue to search thru the forum for info on clarifiers and particulates I found some threads on PhosFree. Could that be my problem? I had some leftover from pre TFP method and from what I read it may not help but it couldn't hurt. The I read it could cause issues with hard to filter precipitates. If that is the case should I use a clarifier or just continue to filter until it clears over time?
    38,472
    Very few members here have any experience with clarifiers because they are typically not needed.
    Most of the reports about phosfree are about it gunking up the filter, I would never use it.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    How are you testing your water?
    Can you please post a full set of test results?
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    Wildcat's Avatar
    Jun 2013
    309
    PH 7.3
    FC 12
    CC 0
    TA 60
    CH 500
    CYA 80
    Water temp 84+
    My TA will fluctuate between 60 and 70
    PH 7.2 to 7.5 Hard to determine because of FC over 10
    FC between 8-12, mostly 10-12
    Keeping TA low to help CSI per suggestions on TFP
    CYA was over 160 at one time, CH was almost 700 lowering slowly by water replacement as I live in the desert
    Wildcat's Avatar
    Jun 2013
    309
    Bought some HTH Natural Clarifier. Threw in 5 oz yesterday evening. Not sure I see any difference yet, will know for sure I guess in a few days. Otherwise pool looks great
    38,472
    That is one reason we do not recommend spending the money on products like clarifier ... They often do nothing.
    Wildcat's Avatar
    Jun 2013
    309
    Yes, I saw mixed results on the forum. If it works it is $10 it is money well spent. If it doesn't I am out $10.
    I don't gamble or smoke, so I took it out of my wine budget
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by Wildcat View Post
    I'd say you gambled. It could have ended up being a lot worse than just being out ten bucks. This thread is not the first report of gummed up gooey filters that defy cleaning.
    Wildcat's Avatar
    Jun 2013
    309
    He also poured a full dose into the skimmer instead of dispersing it over 12,000 gallons like the instructions say. And like one the answers said if the stuff does what it is supposed to do a filter cleaning may be necessary.
    I post back after a week and report on any filter issues
    22,553
    Have you ran an OCLT lately? If not I recommend that you run one. Just for the peace of mind.
    There have been situations where clarifier has helped, but you need to make absolutely sure that there's not something else contributing to the problem.
    Use caution that you do not greatly exceed the mfg's recommended dosage.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    If your dose of clarifyer does not have the desired results, raise your FC to the top of the recommended range, let it circulate 30 minutes, then shut off the pump for 24 hours. That should let most of the particulate drop to the pool floor. Then vacuum manually on the lowest speed setting that you can effectively use and move the vacuum very slowly as to disturb the water as little as possible.
    Love TFP? Become a
    TFP Supporter!
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by Bama Rambler View Post
    I lose 1-2 PPM daily, with pool under constant Arizona sunshine. I have checked it before 3 or 4 days in a row and see the same results.
    Quote Originally Posted by zea3 View Post
    I will try that, but this stuff I have never seems to filter out thru skimmer or drop to bottom, it just seems to float in place while other heavier leaves circulate into skimmer
    Pressure has risen from 10-12 over the last 3-4 weeks, even after adding clarifier this weekend
    Butterfly's Avatar
    South Carolina
    10,045
    Maybe you need to try to change the direction of the returns to get the water circling properly ....... needed for the top to skim.
    You can use ping pong balls to test how the circulation is doing.
    Also, do you us skimmer socks?
    You're done SLAMing when:
    Jul 2009
    Houston, Texas
    9,412
    OCLT shows what you lose overnight when the sun is off the pool. If there is nothing consuming chlorine it should drop less than 1ppm from dusk to dawn. If you are losing more than 1ppm during that time period you have organics consuming the FC and need to slam. Rising pressure may also be an indicator of organics in the water. A nascent algae bloom will give water a dull, grainy appearance before it goes cloudy or full out green.
    Next time you clean the filter, inspect the cartridge well. Make sure there are no small holes or tears in the pleats where debris can escape. The bands around the cartridge should be intact and in good condition as well. As Butterfly mentioned skimmer socks can also help catch fine debris in the water.
    Love TFP? Become a
    TFP Supporter!
  20. Back To Top    #20
    Wildcat's Avatar
    Jun 2013
    309
    Quote Originally Posted by Butterfly View Post
    I appreciate the suggestions but I can see a good circulation pattern. Debris starts on the right side of the skimmer and circulates in a clockwise motion until it goes into the skimmer. Has worked like this for the 6 years I have had the pool.
    Not sure of the purpose of a skimmer sock. The filter material is as fine or finer than the sock so why is a skimmer sock used?
