Thread: 120v light in 12v socket..
    Aug 2014
    Mesa AZ
    54
    Hi,
    We moved into this house last year and shortly afterwards the pool light stopped working. I'm finally getting around to fixing it.
    Anyway, I am 95% sure it's a 12V light fixture because there is a black transformer next to the power switch for my light. Is this a valid assumption? House is an "AZ standard" (cookie cutter) home built ca 1996.
    But when I pulled the light out a) it was half full with water b) there was a weird gel in the bottom not sure if that's part of the insulation or some weird growth and c) there is a 120V 500W light bulb in it.
    Would the light have worked at all if it is a 12V line to a 120V light? I'd think it would, it would just not be nearly as bright and wife says it was never very bright (I don't remember).
    I'm guessing since the fixture has been water exposed for so long I probably just need to replace the whole fixture. Can I buy just the fixture, all I see online are fixtures with a light already included, and I have already bought an LED 12v light bulb online which I guess I could send back.
    Thanks for any pointers!
    Aug 2014
    Mesa AZ
    54
    Red face Re: 120v light in 12v socket..
    Quote Originally Posted by jvrobert View Post
    Hi,
    Umm.. I feel fairly ridiculous. After some research I should have done earlier, I realized that "transformer" is just the j-box, lol.
    Unless someone has other comment my plan is to get an electrician to install a transformer and put in a new fixture with a 12V LED.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Personally, I prefer low voltage in and around the pool. To me, your plan of having an electrician install low voltage lighting is a good one.
    Jul 2014
    Bastrop, Louisiana
    199
    No it will not light up. Not even close.
    I completely agree with Charlie R, get an electrician to look at your lighting. Ask them a few questions to familiarize yourself with your system. Then work from there.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
