- May 3, 2007
- 16,885
- Plaster
- Hayward Aqua Rite (T-15)
chumbley,
In pool mode, you suction is very high. Do you have air in the pump basket when in this mode or is the pump loud?
Normally, it is best to keep the head loss on the suction side to less than 25% of the total head loss. Otherwise the pump gets loud and you start seeing air in the pump basket. Your PB should have used either 2 1/2" pipe or separate pool to pad runs for the skimmer and main drain. Especially with that size of pump.
If you have no plans to modify the plumbing, I probably wouldn't either, then I think you may be best off with a variable speed pump. That way you get the power when you need it but then you can optimize the flow rate for every day filtering. You can go with a two speed, but you won't get the lowest energy usage that way.
