Results 1 to 7 of 7
Thread: New Pool owner doing SLAM need help clearing up
    Jul 2014
    kannapolis NC
    11
    Hi All
    Bought a foreclosure last October which I was told by the realtor had been drained/filled 4 months before we got it. Of course they didnt add any chemicals or do anything to prevent it getting dirty again.
    It is a 40 X 20 pool was told its concrete, not sure what difference between concrete plaster etc.. Its definitely not a liner. A PF-50 Sand filter with fresh sand and a multiport valve.
    It was seriously green when we started. I have removed tons of leaves and scrubbed alot.
    I vacuum when i can as i have a leak so have to fill alot to get to skimmer level. Id like to get clear to be able to see possible leaks. Can the gasket or plate on the skimmer leak into the ground? I did put some food coloring in and saw next to return jet it looked like it was going in there.
    The Water is much more blue now but with a cloudy/hazy look in the deep end.
    Using the tf-100 My results are
    FC 22
    CC .5
    CH 150
    TA 70
    PH 7.2
    CYA 50
    I really would like to get this thing cleared up enough to atleast start to see bottom of deep end and start finding leaks.
    Any help/guidance is appreciate.
    Thank You
    Casey's Avatar
    SW PA
    10,461
    Re: New Pool owner doing SLAM need help clearing up
    You need to MAINTAIN the SHOCK LEVEL. That is called SLAM'ing the pool. It takes time. Some pools clear faster than others.
    SLAMing Your Pool
    It seems you are on the right course. Keep at it.
    Jul 2014
    kannapolis NC
    11
    Thanks I will keep at it. I guess I should have said ive been reading alot and have been doing the SLAM process. Im assuming i shouldnt mess much with other levels than FC while doing the SLAM. I was a bit worried with the CH level fairly low.
    Jul 2013
    Gilbert, Az
    116
    worry about other levels after the slam... what type of filter do you have? please add pool info to your signature so we can see quickly what you have
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Jul 2014
    kannapolis NC
    11
    36000 gallon IG Concrete, Pentair Intelliflo VS , Pentair TA-100D Sand Filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Signature is good Welcome to the forum
    How is it going and what does the water look like now ??
    Solar Blanket, Well Water, Borax Added. 76
    Jul 2014
    kannapolis NC
    11
    Quote Originally Posted by kiss4afrog View Post
    I would really like to THANK everyone and this site for being so thorough.
    Before:
    During which is around the time i posted this much better cant see bottom even in shallow:
    Few days ago
    Its much clearer now i can see the bottom in the deep end and how bad the paint is flaking. My CH is still fairly low and plan on adding more tomorrow. Any suggestions where/what to get to increase CH
    Thanks again
