Thread: pump lost prime
    Jul 2013
    Brampton, ON
    24
    pump lost prime
    hi guys,
    so i had my pool opened late as i had construction going.. the pool was good to go and had a good prime, and i started to vacuum my pool. I attached the vacuum hose to the skimmer, it was sucking up the dirt from the bottom of the pool and suddenly lost prime.. i'm not sure why.. now, i was trying to get the prime back but i'm having a hard time.
    I forced the water using a priming plug and i can see water coming into the pump basket but it's not creating a big suction. I'm not sure what to do.. any help will be good. thanks
    May 2013
    Massachusetts
    148
    Re: pump lost prime
    Make sure you connect the right end of the vacuum hose, if you connect the "swivel end" then your pump will/may lose prime.
    The two ends are not identical although they appear that way.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
