Thread: Chlorine/CYA chart with more options?
    Jul 2014
    Bushnell, FL
    12
    Do you have a chart for Chlorine/CYA levels for slamming purposes for a SWG pool that show the CYA level under 60? The chart for a SWG shows 60, 70, and 80. What if your levels are lower? How do you calculate what your SLAM levels should be if your CYA level is lower? Thanks in advance. (I hope this qualifies as a separate question and not related to my current topic...if so, please forgive me...I am not trying to break the forum rules...I think it is a valid question).
    Intex AG 24' diameter, 13,500 gallon pool with a Krystal Clear Sand Filter Pump 16" (100 lbs. of sand) and SWG (Model CS20110), Bushnell, FL (avg. temp. 85-90 degrees)
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You can use the SLAM levels for a non SWG pool in the chart. 😎
    FC/CYA Chart
    Jeff
    Jul 2013
    Gilbert, Az
    116
    Re: Chlorine/CYA chart with more options?
    yep while slamming and until you get the CYA up to swg levels and get the swg going right treat it like a chlorine pool.... since even with an swg you have to slam with regular chlorine
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Isaac-1's Avatar
    SW Louisiana
    6,711
    For a more detailed chart and explanation see http://www.troublefreepool.com/threa...rine-CYA-Chart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    While shocking, you're using bleach anyway, so treat it as a bleach pool.
    And if you set up the Suggested Levels at the bottom of pool math, it will show you the shock levels even if you selected SWG as your chlorine source.
    Jul 2014
    Bushnell, FL
    12
    Cool! Thanks guys!!! Guess I should have guessed that...my SWG is off now anyway during the SLAM process...it was a little confusing, but will treat it as a chlorine pool, but the other link says 40% of CYA value...that is good to know as well. Easier for me to do that. My CYA level today is about 42, so my shock level needs to be at about 17 ppm, which it is. Will re-check levels tonight, but with this updated information, I don't think I need to add any chlorine. Thanks again for the info. and links!
