Results 1 to 8 of 8
Thread: Algae after 3 weeks of non-use?
    Jul 2014
    Toledo, Ohio
    12
    I was away from my pool for three weeks. I use the trouble-free method and never have any problems.
    When I took the solar cover off upon returning home, the water looked fine, but there are several large light-gray or light-green blotches on the bottom of the pool, both in the shallow and deep ends.
    The water tested:
    TC and FC: 5
    pH: 7.1 (it was 7.5 three weeks ago)
    TA: 100
    CH: 200
    CYA: 20
    While away, I used a chlorine feeder to keep the chlorine up. I normally don't use the feeder. I like to keep the CYA down.
    The pump was on 10 hours a day during the 3 weeks. We live by many trees, and there were a lot of leaves at the bottom of the pool - scattered everywhere.
    Are the splotches algae? I didn't think it could form with the chlorine at 5 or above the whole time.
    Thanks for any help.
    • 17,000 gallon in-ground
    • Vinyl liner (new last year)
    • DE filtering
    • Sta-Rite pump
    Jul 2014
    Toledo, OH
    49
    Re: Algae after 3 weeks of non-use?
    Welcome! Where in Toledo? I've been having a tough time the last couple of weeks with what I first thought was silt. Then it became algae which I cleared with a SLAM. I'm being told that we are having a higher than normal algae problem in our area by several different pool companies. I'm also seeing a collection of pollen in the pool overnight this week. It's been really dry around here this month with July being over 2 inches behind in rainfall. There has to be a lot of dust, and associated chemicals in the air right now. After three weeks under the solar cover, what was your water temperature? Did you vacuum to waste and did the splotches return?
    I've gone out to look for myself. If I return before I get back, have me wait for me.
    16x32x8 Fort Wayne Elite Polymer IG with vinyl liner and 8' acrylic end steps. Hayward S-200 sand filter with 220 VAC Super Pump and VariFlo valve. Installed in 1988.
    Jim
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    An OCLT will let you know if it is organic. Raise it up to shock level after the sun goes down and test to verify your FC. Test again in the AM before the sun gets on the pool.
    Support the site
    Jul 2014
    Toledo, Ohio
    12
    Thanks. I'm in Point Place. The water temperature was 86, although it is 82 now.
    Jul 2014
    Toledo, OH
    49
    Quote Originally Posted by DivingIn View Post
    So am I. Shoreland area. I've had mine uncovered since the breakout two weeks ago. Temp's at 80. Don't forget, we are downwind from the Hoffman Road Landfill. Lots of dust from that thing lately.
    Jim
    Donldson's Avatar
    NW Ohio
    2,917
    Welcome to TFP! I am down near BG, good to see another NW Ohioan.
    How is the circulation of your pool overall? It is possible for areas to have lower FC levels if the circulation isn't very good. When nobody is swimming the bottom can potentially be that place.
    An OCLT should give you an idea. Regular sweeping or brushing will help keep things mixed while we wait for swimming weather to hopefully return.
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2014
    Toledo, Ohio
    12
    There is only a skimmer and a return - no drain or outlet at the bottom of the deep end (8 ft). I was thinking that too, but some of the splotches are in the shallow end by the return.
    I'm wondering if the chlorine just wasn't enough while I was gone. After a pound of calcium hypochlorite, the FAS-DPD test showed 7.2, while the test strips indicated well over 10. Maybe what I thought was 5 was really 2 or 3.
    Quote Originally Posted by jamis View Post
    I'm in Shoreland too.
    Casey's Avatar
    SW PA
    10,457
