Thread: Which pump best for use with Liquidator?
    Jun 2010
    San Antonio
    424
    I need to replace my pump and motor. I am considering the Pentair 347990 Opti Flo 1hp 2 speed 115v or the Hayward SP15922S Power Flo Matrix 1HP 2 speed 110V. My sand filter is 2sq ft and the pool is 7700 gal above ground. I am running the Liquidator on it. I have read where the Hayward has a higher flow rate. So, my question, which one of the pumps will have the best chance of working the Liquidator on low speed? Thanks for any input.
    Larry in Texas
    Above ground 7,700 gallons, 19 inch sand filter ( 2 sq. ft.), Liquidator, and a WaterWay Hi-Flo Pump with an A.O. Smith 1 hp SF 1.0 motor.
    Jun 2010
    San Antonio
    424
    Re: Which pump best for use with Liquidator?
    (Bump) Does anybody have any thoughts on which pump will work best for my application?
    Larry in Texas
