Thread: Loose Bolts on Handrail?
    Jul 2014
    Atlanta GA
    12
    I'm trying to add a basic handrail back to the pool, but the bolts are so loose, they just slide in and out of the holes. Am I missing something? When I took them off last year, they were wedged tight and had to be turned.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Loose Bolts on Handrail?
    The bolts thread into wedges that are loose in the holes. If you unscrewed the bolts all the way, the wedges probably fell to the bottoms of the anchor holes. You'll need to get them started loosely on the bolts, then put the rail in the hole and tighten the bolts the rest of the way.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    If John's explanation didn't make sense: it's the same as the gooseneck for your bicycle's handlebars.
    Jul 2014
    Atlanta GA
    12
    Thanks for your responses. I just realized the guys who re-plastered the pool plastered over the hole for one of the bolts, so I'm going to have to figure out to fix that before I can install it. I'll look for that on the open ones, though, and see if I can't figure it out.
