Thread: Intex pool on concrete slab
    Jul 2014
    Tyler/tx
    2
    I've read several post already on this topic but wanted to see if anybody has actually done it with good results? We have a 24X24 by 4" thick slab and were planning on setting up our 18' X 48" deep Intex pool and wondered if putting sand or foam on cloth before pool is better or not? Thnx
    Re: Intex pool on concrete slab
    Is your concrete slab completely level? Have you verified for yourself with a level? If it is truly level, I would think you could set your pool up on it with a pool pad or mat underneath. I'd wait for someone else to chime in also.
    MrsDimples's Avatar
    Jun 2014
    England
    47
    I have our intex metal frame pool on a concrete slab - it used to be the base of our garage. Also had two intex Easy Set's on it too. I put EVA camping mats on the concrete, protects the liner and makes it lovely underfoot.
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good idea with the mats !!👍
    Jeff
