Thread: Adding a 2nd return on oval pool?
    Jul 2011
    CT
    56
    I have a 2 speed pump and prefer to run it on low with the heater running. With the return on the end of the pool the water doesn't really reach the other end easily. I was thinking of adding a 2nd return on the other end to help heat up faster and to help circulate the water better.
    Is this a good idea or not recommended?
    Sharkline Matrix 15x30x54, Hayward 1hp 2 speed pump, Hayward EC-50 DE Filter, Rome/Solarium 105k Heat Pump, Aquabot Rover Jr - Deceased - looking to replace it
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Adding a 2nd return on oval pool?
    If you can do it without sacrificing the integrity of the pool (watertightness, etc) then it will absolutely be a good idea in my head.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
