Thread: how to connect 1.5" Backwash hose and Intex 2800gph Sand filter
    Jun 2014
    Toronto, ON, Canada
    98
    Hi all,
    I have an Intex 2800 GPH sand filter and a standard 1.5" backwash hose. How can I connect these? I haven't found any adapters that allows me to connect the hose directly to the filter without using an Intex hose in the middle.
    Thanks.
    May 2014
    LA, USA
    16
    Re: how to connect 1.5" Backwash hose and Intex 2800gph Sand filter
    I used 1.5" barb fitting and the modified adapter found on this site for the Intex pool connections
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    Mid Missouri
    227
    My new pump came with new Intex hoses. I used one of my old intex hoses to make my adapter.
    1- On one end I cut the "flange" off with my miter saw.
    2- Slide the gray "nut" off.
    3- The backwash hose fits perfectly over the end that is left.
    4- Attach with hose clamp.
    I'm not sure what size backwash hose I used if they offere multiple sizes, but it is standard from the backwash hose section.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
