Results 1 to 8 of 8
Thread: 73% Cal-Hypo ques
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    73% Cal-Hypo ques
    This turbo shock I have says 75% chlorine and 22% other ingredients. I checked the effects of pool chemicals and it didnt say it adds any cya. Just CH and salt. Does anyone know how much cya a 16oz bag will raise the cya? Just wondering.
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    38,279
    Re: 73% Cal-Hypo ques
    None. It only adds calcium. Dichlor and Trichlor add CYA.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Thanks again Jason for answering my questions. So since my CH is low anyway,150, this stuff should be good to use to super chlorinate my pool if it needs it since it is 75% chlorine concentrate
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    If you maintain the right FC levels consistently, you may never need to superchlorinate aka "shock." You can use that stuff instead of bleach until the CH gets up to 300 or so.
    38,279
    But you have a vinyl pool and low CH does not matter.
    Also, usually bleach is cheaper if you look at cost per ppm of FC.
    Richard320's Avatar
    Jan 2010
    18,995
    But since he already has a bucket of the stuff, it requires no further cash outlay.
    38,279
    True. I would not suggest buying any more though.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    That is the plan, I've been following the TFP method and the water is crystal clear. I'm just looking at the chems I've already bought and the only thing worse than spending money I didnt need to is looking at it sitting there. I appreciate the help.
