Thread: Draining down to reduce CYA
    Well I'm standing in about 10" of water on the shallow end right now. My CYA was about 180 on the diluted k2006 test. Took sample to pool store and they said 150 which I bet is low.
    Any suggestions on refill from here and proper actions would be appreciated. I will get a chance to change my pool bulb during this fun though.
    Also stained liner and step suggestions as well please.uploadfromtaptalk1406769433877.jpguploadfromtaptalk1406769449037.jpguploadfromtaptalk1406769486068.jpg
    Brandon, MS
    20000 gallon
    IG vinyl
    sand filter
    hayward .5 hp pump (I think)
    Brandon, Mississippi
    20000 Gallon Vinyl Inground
    Sand Filter with Hayward Super 2 - 1 HP pump
    K-2006 Kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Draining down to reduce CYA
    Is your fill water from your own well? If it is, have you had it tested for iron?
    While you have the steps out of the water, try crushing a few vitamin C tablets, and make a thin past from them. Wipe this paste on the steps, and see if the staining goes away where you wipe. Rinse it off with your pool water after the test.
    City water for the refill.
    Brandon, MS
    20000 gallon in ground vinyl
    sand filter
    hayward super 2 - 1 hp pump
    K-2006 Kit
