Results 1 to 9 of 9
Thread: Upgrading Intex filter?
    Jul 2014
    Charleston/SC
    13
    Hi everybody!
    In June we bought and installed our first above-ground pool. We started with an Intex 15ft X 48inch round. It took me a few weeks to get the hang of the chemical thing and keep it from getting algae, but thanks to this forum, we have a beautiful clear pool that the kids LOVE to play in. BUT, our filter keeps cutting off and not wanting to start back up. Today it wouldn't come on at all. We put in the call to Intex and they are sending a new one. I have no idea how long that will take! I think we should upgrade though. I have read that the filters that come with the Intex pools aren't really big enough to handle the amount of water in the pools. If that is true, what filter should I upgrade to that will be compatible with my pool? I would hate to trade one problem for another. Like will a new filter fit with the hoses for my pool?
    Any thoughts?
    4440gal Intex AG Vinyl Krystal Clear Model 637R Cartridge filter pump 1000gph 6/24/14
    38,369
    Re: Upgrading Intex filter?
    First, filters do not "run", the pump motor does.
    Many members liked the 2650 pump with the sand filter.
    Mid Missouri
    227
    I like my intex 2650gph sand filter. It has a 16" filter and holds about 100 lbs of sand. Your pool is on the smaller side, however I don't think it would be overkill.
    Oct 2012
    Houston, TX
    186
    Yep, either the 1,600 or 2,650 intex sand filter hooks right up and is a big upgrade. Which one you get depends on how much you want to spend. For 4,400 gallons the 1,600 is fine, which is what I have foe my 4,000 gallon pool. Turnover is fine for that size pool.
    1,600 gph is 1/2 hp whereas 2,650 is .95 hp, so higher cost per pump hour. Considering a lot of people have 3/4 to 1 hp for pools 3 times as big, I think 1/2 hp is fine. Main advantage is increased filter area which means less frequent backwash, but not sure that outweighs increased electricity cost.
    I'm sure some will disagree. Just offering my. 02.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Mid Missouri
    227
    Quote Originally Posted by hyperionguy View Post
    I believe Intex is using "peak" ratings rather the true HP ratings. But irregardless it is a fact the 2650 is going to use more electricity than the 1600 hour for hour. If you don't have an Intex SWG you can offset that by shorter run time if that's a concern.
    It took me a while to decide between the two. Obviously I ended up with the 2650. Because I have a SWG the larger filter and less frequent back washing appealed to me. Also coming from the cartridge filter I wanted to make sure I ended up with plenty of flow for vacuuming.
    Probably can't go wrong either way. 2650 would provide some extra capacity if you think you may want to move up to a larger Intex pool in the near future. But the 1600 would probably be plenty to get you by with what you've got.
    Decisions decisions.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Thinking further down the line...... If you ever might think of upsizing your pool (your Intex might last 4 years), I would go with the bigger.
    I cant speak to the increase in electric, I cant imagine it being more than 7-9 dollars/ month. but the less frequent backwash mean you wont have to balance the refill water more often.
    The bigger pump will filter the pool faster so theoretically you wont have to run your pump as long.
    The bigger pump will also run any automatic pool vacuum you might want to get in the future.
    Personally I would go with the bigger, but if you look at my signature you will see I am in major overkill zone with my pump/filter now. (We are upgrading pools big time next year)
    Good Luck and welcome to TFP!
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    I'm in the same boat with my 16x48, I'd rather get 2650 and be overkill than 1600 and regret
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Mid Missouri
    227
    Quote Originally Posted by Slammed01 View Post
    There was a discussion similar to this when I was deciding between the two a couple years ago. There was a quote in there that really kind of cemented my choice.
    Somebody commented in reference to the 2650; paraphrasing "Yea but isn't there a such thing as too much pump"
    One of the moderators replied "Yes there is, but this isn't it"
    For me the decision was made, and the 2650 was ordered. No regrets.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
    Jul 2014
    Charleston/SC
    13
    Thanks for the input, everyone!
