Thread: Salt concentration?
    Jul 2014
    St. Simons Island, GA
    172
    Salt concentration?
    Intex SWG manual says 2,500 to 3,500 ppm for salt, with 3,000 ppm being ideal. Taylor K-2006 test kit has no salt test, so I'm stuck using a dip & soak strip which returns a result of about 1,400 ppm. Intex SWG indicators says "working", with neither high nor low salt concentration being indicated.
    Recommendations?
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    Mar 2014
    Las Vegas
    288
    Re: Salt concentration?
    Run with it. When I did my salt install, I used test strips. Kept adding salt until the strip looked like 3000. When I ordered my TF-100 I also ordered the Taylor drop based salt test kit. I had 5400 ppm of salt. I started getting high salt idiot light and did a couple of small partial drains and my SWG is now happy at 4600 ppm.
    If the SWG is happy, leave it alone.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Treat the SWG like your wife.
    If she's happy, you should be happy.
    Jul 2014
    172
    L.O.L. !
